Post
- Model of CNC Machine: laguna
Post
I have a Laguna IQ and when I go to save to my PP it does not have one for the Laguna. How can I fix this?
- mtylerfl
Re: Post
Hi Joey,
There might be someone here that can help (I hope so), but have you checked in with Laguna Tech Support on this?
Re: Post Processor
When I go to save to my Post Processor their is not one for Laguna
- highpockets
Re: Post
I don't have PhotoVCarve so I hope I'm not steering you wrong...
Open up PhotoVCarve on the File menu option select Open Application Data Folder. Open the folder PostP and look for Laguna_IQ_xxxx. I have a couple of Laguna_IQ pp options, I can't tell you which one you should use.
Hope this helps.
If the Laguna pp files are not there then I'm with Michael, contact Laguna Tech Support.
Hope this helps.
Re: Post
PhotoVCarve doesn't have the Open Application Data folder option. The posts are stored within the PostP folder in the Program Files folder where the program is installed.
- highpockets
- scotttarnor
Re: Post
I have never used Photo Vcarve to create the tap file because there were none available for the Piranha either, I always save the file as a .pvc and open it in Vcarve, it is an extra step but I feel it is worth it because Vcarve gives a better preview than Photo carve IMO.
Scott T
@scottscnc
@scottscnc
