Litho in colored Corian
Has anyone tried cutting a lithophane in colored Corian? If so, does the photo show up ok? I was given a couple of pieces of blue and wondered if it was even worth trying to do a litho with it or if it would be way too dark for the photo to show up well.
- Model of CNC Machine: Router
Litho in Blue Corian
IYWD.
The only way you are going to illuminate your Blue Corian Litho is, after cutting it, you will need to set off a small "H-Bomb" behind it!! hehe.
Warren.
Warren.
That's kind of what I figured. I had thought of trying to cut a underwater photo of fish, that a friend that goes diving a lot took, (thinking maybe the blue would make it look like ocean water), but I was afraid the fish may not show up. Oh well, just a thought. Guess I'll just make a cutting board out of it or something.
Thanks for the input.
Susan
IYWD
Susan
IYWD
color and corrian
Check out this web site! [b]http://www.babbart.com/index.html[/b]
Becki Babb carves in corrian and has several examples of back lighting. She also has some that are painted on the back so the color shows through. Check out the bath tub in her sample pages.....Flat on the front, but when lit from behind, an entire sea scape.
