After three weeks of trial and error
Alwaysforward
Model of CNC Machine: X-Carve Pro
Post by Alwaysforward »
These are not yet clear coated but I think they are about as good as I can get them. Anyone have any tips on how to dial them in better?
Photo V-Carving 1
Photo V-Carving 1
Photo V-Carving 2
Photo V-Carving 2
Re: After three weeks of trial and error
Post by adze_cnc »
One way is to alter the tonal range of the source image. This is the sort of thing that needs to be done with laser engraving.
Example video: https://www.youtube.com/watch?v=bR1qqsy2nn0 (8 mins 30 secs)
Post by Rcnewcomb »
Are you using a scraper blade as part of your process? That gives you the ability to lighten certain areas.
Alwaysforward
What is a scraper blade?
Post by Rcnewcomb »
Cabinet scraper.
Card scraper.
You can also use a single edge razor blade.
Alwaysforward
Thank you for the feedback. So instead of sanding the carving after staining you simply use the scraper? I’ve tried various things over the past few weeks and look forwarded to trying this. I presume light pressure and following the carving lines correct?
Post by Rcnewcomb »
Start that way and then try varying the direction of the scraping pattern.
Start out on some of your "failed" photoVcarves. I think you will find the scrapers give you far more control compared to sanding.
Alwaysforward
No post processing. Right off the machine.
Alwaysforward
Latest Photo V-Carvings
CURST991
Model of CNC Machine: SELF
Post by CURST991 »
What type of bit did you use in order to carve into the acrylic for the pelican pic?
