1911 Grip with USMC Globe & Anchor
wb9tpg
Post by wb9tpg »
I'm really loving the laser module. I had to alter the GRBL post processor to remove any Z motion. At first I was tempted to remove the Z entries but I decided to use the scale factors to accomplish the same thing by reducing the motion to 0.
Here are the entries in the customized PP and I thought this was a clever approach to share. I also included the $32=1 at the beginning so I never forget to turn it on/off. I can almost do it with one post processor if it had one more tweak to it.
+ Reduce Z motion to 0
VAR Z_POSITION = [Z|C|Z|1.3|0.00001]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3|0.00001]
And the new Laser Module does really nice work. J-Tech 4.2W spindle mount laser (80% Power / 1100mm / min).
Gary Mitchell
Kentucky, USA
Re: 1911 Grip with USMC Globe & Anchor
Post by mtylerfl »
Very nice, Gary!
Jan.vanderlinden
Model of CNC Machine: Xcarve
Post by Jan.vanderlinden »
That's sweet.
Great job.
Post by TReischl »
Nice job! I see your fixture seems to be working really well too.
Bob Reda
Post by Bob Reda »
I like that!
Bob
wb9tpg
Post by wb9tpg »
And Walnut and Cherry too
Gary Mitchell
Kentucky, USA
Post by mtylerfl »
Wow, those are beautiful!
You’ve really got a grip on things, Gary! :D
wb9tpg
Post by wb9tpg »
And I'm in a US Navy mood today. First time playing with scaling a STL on one axis only during the import. Also, I tried Hatch Fill with the Laser Module for the first time. It all worked. I think I finally for my post processors sorted out.
Gary Mitchell
Kentucky, USA
Jan.vanderlinden
As I mentioned before, beautiful piece of work.
But I gotta ask.
You mentioned before that you set the Z to zero movement.
If that's the case, are you not loosing focus when burning the on the curvature of the handle?
I have the J-Tech 7 watt, and the focus is at 1.5", which is .125" above the work.
Being that it has a shroud on it, that doesn't leave much room for Z travel. (3D work)
I've been doing all flat work with other laser software.
Last edited by Jan.vanderlinden on Fri Jul 17, 2020 10:09 pm, edited 1 time in total.
wb9tpg
Post by wb9tpg »
The depth of field for the laser is large enough that you can easily get away setting it to 1/8" above the workpiece and running the job that way. Keep you from breaking your laser unless you're careless
Gary Mitchell
Kentucky, USA
