Fixed Z Height (Laser Position) Throughout Program
Samarah
Model of CNC Machine: AvidCNC PRO4848; 6W Opt Laser; UCCNC
Post by Samarah »
This is probably a simple solution, but I finally give up and am asking for help.
I'm trying to get the Z height to remain the same through the entire laser program, no retract on any moves until the retract to Z-Home at the end of cutting. I can seem to set the clearance to zero without manually editing the code.
I am attaching a simple part with a few shapes, the g-code, and the post processor.
laser-shapes.crv3d
(54 KiB) Downloaded 38 times
UCCNC_OPT_Arcs_mm.pp
(5.63 KiB) Downloaded 38 times
Laser Cut Shapes.txt
(1.86 KiB) Downloaded 34 times
AvidCNC PRO4848; 6W Opt Laser; UCCNC; Aspire 11.5
Tex_Lawrence
Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 12.004
Re: Fixed Z Height (Laser Position) Throughout Program
Post by Tex_Lawrence »
Try this link on the "no Z" post processor: viewtopic.php?p=275782#p275782
What you're asking for is done in the post processor.
Tex — Crooked Wood Products
Samarah
Post by Samarah »
Thanks Tex.
Much appreciated. It worked great!
I would have never thought of using the multiplier to essentially make it zero.
wb9tpg
Post by wb9tpg »
Samarah wrote:
Fri Feb 10, 2023 2:50 am
Thanks Tex.
Thanks. I love coming up with innovative solutions.
Gary Mitchell
Kentucky, USA
Tex_Lawrence
wb9tpg wrote:
Fri Feb 10, 2023 5:10 am
:D Didn't intend to "shade" your effort, Gary! :lol: Of course, Gary is the source for this post processor knowledge on the laser posts!
Thanks again, Gary!
wb9tpg
Post by wb9tpg »
Never took any slight at all. Glad to see the knowledge being shared. I’m going to replace all my existing post processors soon with a single one using lua.
Gary Mitchell
Kentucky, USA
Samarah
Post by Samarah »
Thanks for the solution Gary.
