Hello All,
Is anyone running a Creality CV-01 Pro machine with the Laser Module for VCarve Pro 11.5 yet? I would like to add this machine as it doesn't cost an arm and a leg at this time ($129.00USD + Tax) plus the cosst of the Laser Module. If it actually works out, I can then think about adding a real laser to the shop.
Thanks in advance,
Jim
Creality CV-01 Pro Laser
- Model of CNC Machine: Shark SD100 & Shapeoko 3 XXL
Re: Creality CV-01 Pro Laser
Vectric can't list each and every machine available. At the Creality product page (you can find quite a bit of info there) I expect will list GRBL which is something the Vectric laser module should support.
- Model of CNC Machine: Custom homemade
I’ve run laser on Bibo 3d printer, it is similar.
There are limitation - using fan control to control the laser, not sure how much power it can supply. I use 0.5W laser with about 500 mm/min speed for small projects.
There are no direct post processor. I made gcode in Vectric and manually edited it.
Works fine for my hobby toys,
There is a way to make gcode in Incskape through extentions and it works with small corrections but I like Vectric laser module better.
I have a project that I am working on that some might find interesting. I have an Ender 3 Pro 3d printer that I am in the process of converting from a 3d printer to a laser engraver. Nothing new, I know. but I have completely removed the hot end and am installing the 1.5 laser in it's place. I've designed a holder for the laser that uses the hot end screws to hold it in place, rather than rely on the magnets.
I have been using VCarve with the Laser Module for designing some test cuts, but can't find a post processor for this laser unit. I am working on creating the VCarve post processor file to setup the Ender with the laser attached, so I can port my VCarve laser module gcode designs directly to the Ender.
If anyone is interested I can post links to the laser holder CAD and stl files, as well as the Post Processor file.
I’ll be interested in Post processor
Thank you!!!
Thank you!!!
If you don't want to reinvent the wheel: https://jtechphotonics.com/?p=19034
