I am seeking to cutout a laser cut file on 1/8" baltic birch using the laser.
I can engrave without any difficulty. What I can't seem to do is cut through the 1/8" wood.
I am using the g2 lens and I have tried various power, speed, and number of passes, and the most I can get is 1/4 through the wood.
Does anyone else make these type of cuts? Please advise. thanks.
Laser Cutout with Aspire (current) & Laser Module
- Tex_Lawrence
Re: Laser Cutout with Aspire (current) & Laser Module
Are you using a baltic birch plywood?
I use a 7 watt JTECH laser. It will eventually burn through, but it isn’t all that easy. I’ve burned pockets through 0.1” plywood. It usually takes 8 passes at a slow pace. Lots of smoke.
Tex — Crooked Wood Products
- Model of CNC Machine: Sienci Long Mill
Although this is not a Vectric solution, make sure that your laser is perfectly focused. The include gauge is not accurate enough. I suggest using the "ramp method" recommended by the LAHobbyGuy.
Also, allowing Z to lower between passes will help.
I don't see a way on vectric laser module to set z step depth... Or is this something I have to do manually?
Yes, using baltic birch. I did 100 passes with 100% power at a rate of .25 in/sec and finally got through, but the burn path was so wide that on a larger project, a regular bit is going to be better.Tex_Lawrence wrote: ↑Sat Sep 03, 2022 12:18 pmAre you using a baltic birch plywood?
But I have intricate cut-through detail I need to accomplish and even using the 1/16" fem will break the wood. :::sigh:::
I hear about people doing laser cutting all the time. I guess I thought it would be able to handle 1/8" baltic birch.
I did order some 1/16" baltic birch, maybe that would make a difference.
The other thing I considered was that it is the software, the vectric module. Like I mentioned somewhere, I don't see a way to indicate how much to laser per pass depth. I took a look at other laser software... and gracious... another software to have to learn.
- Tex_Lawrence
Laser “cutting” is generally done with a desktop machine using a 30watt and up non-diode laser. Think of your laser as a precision engraver. You’ll be more satisfied using it that way.
Many of these laser modules come with Light Burn or some other such software. Have you tried cutting through your 1/8” (more like 3mm) BB ply with that software?
If those dedicated software packages have a difficult time so will the laser module here. If they don’t have a difficult time what’s the difference between the two?
You also might want to look at a few minutes of this video (link starts at 5:49)
