So this is not vectric related as I use other laser software for laser work (V-Carve Pro for everything else), but I don't think it is software related as I have tried similar files in multiple softwares with the same results.
So the beginning of every fill path offsets the first 4-5 lines but then corrects itself after that. It is the exact same on every file no matter how large or small. I am using a Trocen AWC708C controller and I have messed with every setting I can think of to get it to stop. I don't think it is mechanical or it would be a little more random, this is the exact same for every fill path. I really think it is controller related, I just can't find the issue...anyhow...Any ideas would be much appreciated. See picture below for an example.
