Laser Toolpath Processing Time
Chada13
Model of CNC Machine: Shark HD4 Extended Bed
Post by Chada13 »
I've processed many files with the Laser toolpath. But recently the processing time has increased drastically. It may take 5 minutes to process a simple Laser toolpath (before it only took seconds). Plus in the preview, the result displays a really thick toolpath.
I have the display set to standard. The laser kerf is still 0.1". The vectors are clean with minimal points.
I don't know what could be driving this. Other toolpaths process quickly, even for larger files.
Any help would be appreciated!
Chad
Re: Laser Toolpath Processing Time
Post by Rcnewcomb »
Can you upload an example file that is showing the problem?
How do I upload files or photos to the forum?
Chada13
Post by Chada13 »
Attached is the culprit. Thank you.
Blade and Bow CRV2.crv
(1.68 MiB) Downloaded 91 times
Post by TReischl »
A .1" kerf is a HUMONGUOUS laser kerf!
Chada13
Post by Chada13 »
It was the kerf. Not sure how it got to that size. I changed it to .01" and it processed super quick.
Thanks!
