Hi, working within Aspire and projects with CNC and laser toolpaths I find that I have to change the material clearance and plunge, recalculate just the laser paths. This saves a good bit of time by removing the unnecessary movements when using my laser.
Could you add additional fields for laser clearance and plunge settings that would only be used when using a postprocessor for lasers?
Jimmy
Feature Request - Separate laser Clearance & Plunge settings
- Model of CNC Machine: Shark HD4 Ext
- TReischl
- Model of CNC Machine: 8020 Build 48X36X10 RP 2010 Screenset
Re: Feature Request - Separate laser Clearance & Plunge settings
Requests like that are best sent direct to Vectric via email. They may or may not read your post here at all.
Hi Jimmy,
Thanks for the request. I can definitely see why you might want to do this. I'll talk to the Development team and record it in our Wishes list.
Cheers,
Adam
Cheers,
Adam
