Tapered Inlay (Paul Zank method) Plug with Rough Clearing: release
adze_cnc
Re: Tapered Inlay (Paul Zank method) Plug with Rough Clearing: release
Post by adze_cnc »
Version 1.45 gadget update:
  • fixed reference to undeclared items. This might be preventing running under Aspire v4.5
If you are running v1.4 you don't really need to update. But as it's easy enough to update there's no harm in doing so.
Installation Instructions
Because the forum software doesn't allow attachments with ".vgadget" extension the file is uploaded as "Tapered_Inlay v1_45.zip". Installation instructions are the same for both new installation or in upgrading a previous version:
  1. download the gadget attached below as: Tapered_Inlay v1_45.zip
  2. rename it to: Tapered_Inlay v1_45.vgadget
  3. in Vectric Pro or Aspire click on then menu option: Gadgets -> Install Gadget
  4. navigate to where the downloaded and renamed file is
  5. select it and click Ok.
VCarve/Aspire should give you a pop-up saying the gadget was installed and you should see "Tapered Inlay" in the Gadgets menu.
Note: after downloading the ZIP file do not extract it but continue on to the rename operation (unless you are running Aspire v4.5 in which you need to manually unzip and move the folder to where your gadgets are stored).
This gadget works in Aspire and VCarve Pro version 9 to 11.
I have not tried it in version 10.x but as that version uses the same toolpath selection as v11.x it should work. I have also not tested it in a version less than v9.x but I suspect it might work (though an Aspire v4.5 user is helping to see if we can get it to run on v4.5). Choose a tool and if you get no errors it should work.
Rename to "Tapered_Inlay v1_45.vgadget" after saving
(45.04 KiB) Downloaded 169 times
adze_cnc
Post by adze_cnc »
Version 1.50 gadget update:
  • altered to work under VCarve 7.x & 8.x as well as Aspire v4.5
Because the forum software doesn't allow attachments with ".vgadget" extension the file is uploaded as "Tapered_Inlay v1_50.zip". Installation instructions are the same for both new installation or in upgrading a previous version:
Instructions for Aspire and VCarve Pro versions greater than v8.x
  1. download the gadget attached below as: Tapered_Inlay_v1_50.zip
  2. rename it to: Tapered_Inlay_v1_50.vgadget
Note: after downloading the ZIP file do not extract it but continue on to the rename operation (unless you are running Aspire v4.5 or VCarve v7.x in which you need to manually unzip and move the folder to where your gadgets are stored).
This gadget has been tested to work in Aspire v4.5 and versions 9 to 11 and in VCarve Pro versions 7 to 11.
I have not tried it in version 10.x but as that version uses the same toolpath selection as v11.x it should work. Choose a tool and if you get no errors it should work.
(45.22 KiB) Downloaded 345 times
RickW3DS
Model of CNC Machine: LongMill 30x30
Post by RickW3DS »
adze_cnc
Great gadget!
This is my new go-to for inlays!
webb
Model of CNC Machine: OneFinity Journeyman
Post by webb »
Good Morning,
The gadget seems to produce the base and not the plug. I'm sure the issue is on this end - can you take a moment and set me on the right path?
Jim
adze_cnc
Post by adze_cnc »
Jim,
No constraining vector around the house shape to make a negative positive:
Will cut the crab and seaweed as a negative shape (as per your house)
Adding a border makes a negative into a positive
webb
Post by webb »
Perfect! It works. Thank you so much.
adze_cnc
Post by adze_cnc »
I did a preliminary test with v11.5 VCarve and all seems to work fine.
There is an issue that it doesn't save the last bits used with Vectric software versions 10 and above but I already knew about that and will fix it anon.
Steven
hobbyist
Model of CNC Machine: onefinity x50 woodworker
Post by hobbyist »
I'll have to give this a try.
in the simulation it seems to work well.
do you think this would reduce the chipout?
Also is there one for the Base (female part)
Thank you
Mike
"Not all Who Wander are Lost" (J.R.R. Tolkien)
adze_cnc
Post by adze_cnc »
hobbyist wrote:
Fri Oct 20, 2023 12:45 am
Chip-out is pretty much feed rate, spindle speed, bit geometry, and depth of cut dependent. This was meant for those whose machines can't handle plunging all the way down to the plug start depth plus the bit's pass depth which might be quite a depth.
I had thought of having it do both halves of the inlay but the base doesn't really need anything special as it's a plain old V-Cave/Engraving Toolpath.
