Hello All,
I hope your dust-collector keeps the chips moving in the right direction.
I needed a Cycloid today for a gear tooth I am working on and recalled I had made a cycloid gadget some time ago. Well, after looking at the old version, it really needed some work.
So, have a look at my version 2.0 of the Easy Cycloid Maker.
Note: This gadget should work with Version 7.0 and higher.
How to use:
1. Draw a line to represent the base (Can be on an angle) of the Cycloid.
2. Select the line.
3. Run the EasyCycloidMakerVer2.0 gadget.
What did you mill today?
Easy Cycloid Maker
- jimandi5000
Easy Cycloid Maker
- EasyCycloidMakerVer2.0.zip
- Rename to: EasyCycloidMakerVer2.0.vgadget
- (1.69 KiB) Downloaded 138 times
Jim
Jim
