Hello All,
I hope you are having as much fun as I am.
The other day, there was a post about Fence Post Caps and how to mill them.
Just for fun, this is what I came up with....
Note: This gadget requires Version 10 or higher.
1. Enter the size (Squair or Rectangle)
2. Enter the size of the Flat Amount (can be zero)
3. Select the bits (Note: the detail level is controlled by the "Bit Stepover amount")
4. Press Ok!
Next Steps:
A. Build the Easy Fence Post Cap Maker help web page
B. Write a "Gear Gadget" that is made for Milling
- jimandi5000
- EasyFencePostCapMaker.zip
- Rename to: EasyFencePostCapMaker.vgadget
- (39.86 KiB) Downloaded 178 times
Jim
Jim
