Easy Zank Toolpath Maker
- jimandi5000
Hello all,
Here is the EasyZankMakerVer2.0 gadget. The gadget creates a set of stepping toolpaths for the creation for the Inlay (Male) portion of a inlay project.
Special thanks to the excellent guidance from several members wire they have graciously sent me numerous reference materials, links, and drawings to ensure I understood the challenge. Here is one of the links that provides in-depth details viewtopic.php?f=3&t=564
Even though there is a known issue in the "Create-V-carve" function within the SDK, the gadget still delivers a series of toolpaths that are calculated based on selected V-bit "Depth-Of-Cut" to reduce the possibility bit breakage and mill stalls.
Please let me know if you have any suggestions.
- EasyZankMakerVer2.0.zip
- Rename to: EasyZankMakerVer2.0.vgadget
- (35.2 KiB) Downloaded 304 times
Jim
Jim
- mfirlott
- Model of CNC Machine: Stinger 1 (2014)
Re: Easy Zank Toolpath Maker
How is it installed. I unzipped and tried from within Aspire (Install Gadget) but it could not see the lua files???
Thanks.
Thanks.
(Mitch)
CAMaster Stinger I
Vectric Aspire
Epilog 45watt Helix Laser
CAMaster Stinger I
Vectric Aspire
Don't "unzip".
- download "EasyZankMakerVer2.0.zip"
- rename to "EasyZankMakerVer2.0.vgadget" (see caption in Jim's link above)
- either "double-click" to run from Windows Explorer or in VCarve/Aspire under the Gadgets menu choose "Install New Gadget..."
- mfirlott
Thank you.
(Mitch)
CAMaster Stinger I
Vectric Aspire
CAMaster Stinger I
Vectric Aspire
I may be dense as can be. I have been fighting most of the day getting the latest version of Parallels to work right. I cannot install this gadget. I have not installed one in a while. I have downloaded it in Windows 10 and Mac, not unzipped it, added .vgadget, unzipped it — no success, and not unzip and try to load from Aspire — all to no avail. I guess I need more specific instructions. Regardless of unzipping before or after adding .vgadget, the files have the extension .lua or .xlua. and are not recognized. If the folder is unzipped Aspire does not recognize it.
- jimandi5000
Hi Wayne,Wayne Locke wrote: ↑Mon Aug 23, 2021 10:27 pmI may be dense as can be. I have been fighting most of the day getting the latest version of Parallels to work right. I cannot install this gadget. I have not installed one in a while. I have downloaded it in Windows 10 and Mac, not unzipped it, added .vgadget, unzipped it — no success, and not unzip and try to load from Aspire — all to no avail. I guess I need more specific instructions. Regardless of unzipping before or after adding .vgadget, the files have the extension .lua or .xlua. and are not recognized. If the folder is unzipped Aspire does not recognize it.
Let me help you.
1. Download the file to your "Download Folder" and do not move it.
2. Rename the file to "EasyZankMakerVer2.0.vgadget".
3. Open Aspire and pull down the Gadgets menu.
4. Select "Install New Gadget..."
5. Navigate to your "Download Folder" and select the "EasyZankMakerVer2.0.vgadget" file
6. You should receive confirmation of new gadget added.
7. Pull down the Gadgets menu and you should see "EasyZankMakerVer2.0" available.
I also show how to load a gadget on YouTube. (You will need to maximize to see the entire video area)
https://youtu.be/dG0C5HCX7sE
Please let me know this helps.
Jim
Jim
- Model of CNC Machine: my own design
I played with this yesterday.
The original download was xxx.zip but the extension was not showing. When I renamed the file it became xxx.vgadget.zip.
I renamed the file to xxxinstall .vgadget and the process worked.
You must be able to see the file extensions to rename properly.
I'm still on 9.5 but that's another problem.
Ed
Ed
- jimandi5000
Hi Ed,
The setting to display file extensions is in the file explorer's menu. You can easily turn it on and off with the check box.
I am having you got it working.
Jim
Jim
Thanks all. The .zip was not showing. I turned on the extension name, renamed it, double clicked and bingo. It was so obvious but elusive — at least it wasn't't a snake. Thanks.
- jimandi5000
Wayne Locke wrote: ↑Tue Aug 24, 2021 2:16 pmThanks all. The .zip was not showing. I turned on the extension name, renamed it, double clicked and bingo. It was so obvious but elusive — at least it wasn't't a snake. Thanks.
- Nailed IT.png (23.28 KiB) Viewed 18660 times
Jim
Jim
Jim:
There is a significant error in the gadget. It doesn't actually use the tool's v-bit angle and instead writes 90 as a default. See this thread: viewtopic.php?p=280401#p280401
The fix is quite easy. You can also uncomment the RegistryRead and RegistryWrite entries to allow it to save the default.
Find all occurrences of
and replace them with
While you're at it could you change the wording on the HTML screen from "Clearing v bit" to "Clearance tool"? "Clearing v bit" is confusing as it's an END_MILL type not a V_BIT type.
Steven
PS: No offence but I really didn't like using the gadget. In a way it's too complicated. I'll put some thought into making it easier to use in the next couple of day. This would be based on my post viewtopic.php?p=280382#p280382 near the top of the aforementioned thread.
Code: Select all
VBitAngle
Code: Select all
VBit_Angle
Steven
- jimandi5000
Hi Steven,adze_cnc wrote: ↑Sun Oct 10, 2021 1:15 amJim:
and replace them withCode: Select all
VBitAngle
While you're at it could you change the wording on the HTML screen from "Clearing v bit" to "Clearance tool"? "Clearing v bit" is confusing as it's an END_MILL type not a V_BIT type.Code: Select all
VBit_Angle
Steven
No offence taken.
Thanks for the feedback and code guidance. I always welcome the input.
Jim
Jim
- jimandi5000
Hello everybody,
I hope your happy and joyful this beautiful day.
I have completed the updates to the gadget and now the current Version is 3.5. We still have a broken "CreateVCarvingToolpath()" function within the API library. We will do our best managing these issues until the development team get some time to address the issue.
As a side note, I truly appreciate the back from Steven on the gadget and I look forward to his input on making it a more usable tool.
Please let me know if you see any issues.
The Gadget Supports Vectric PRO and Aspire versions 10+
- EasyZankMakerVer3.5.zip
- Rename to: EasyZankMakerVer3.5.vgadget
- (35.2 KiB) Downloaded 139 times
Jim
Jim
EDIT: I recommend not downloading the ZIP file just yet.
Jim: the ZeroBrane debug link is still in the LUA file:
Original Post:
A reminder that after downloading you to rename the ZIP file to:
as per Jim's post above: viewtopic.php?p=278159#p278159
Code: Select all
require("mobdebug").start()
Original Post:
- jimandi5000
Thanks Steven for catching that issue!!!
I have corrected the code and here is version 3.6
Supports: Vectric 10+
- EasyZankMakerVer3.6.zip
- Rename to: EasyZankMakerVer3.6.vgadget
- (35.2 KiB) Downloaded 160 times
Jim
Jim
