Easy MDF Cabinet Door Maker
- jimandi5000
Re: Easy MDF Cabinet Door Maker
Hi Benjamin,
I am fixing the code and have to ask... what dose it mater on how the lines are drawn? The milling is the same. right?
Jim
Jim
If cutting on the line it makes no difference. My guess is the original poster is cutting to one side of the line. Two of the lines (e.g. the two top ones) will align with the panel bevel and two won't (e.g. the two bottom ones)
- jimandi5000
Hi Benjamin,
I have fixing the code as per your request.
Here is Version 10.5 of the gadget.
- EasyMDFDoorMaker.zip
- Rename to: EasyMDFDoorMaker.vgadget
- (974.4 KiB) Downloaded 178 times
Jim
Jim
- jimandi5000
Hello All,
I have been working on the Easy MDF Door Maker and I have added the milling of the raised panel section, mills the flat section, and mills the inter and outer door edges. It will also mills the Scribe lines if you select "Yes" to Scribe Lines and select tooling for the scribe lines. It will mill fluting lines if they are drawn and tooling is selected.
The Easy Install Steps:
1. Download the gadget EasyMDFDoorMaker.zip that is attached to this post.
2. Rename it from EasyMDFDoorMaker.zip to EasyMDFDoorMaker.vgadget
3. In Vectric Pro or Aspire click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it and click Ok.
If successful, a pop up saying the gadget was installed and you should see EasyMDFDoorMaker is now in the Gadgets menu.
What is New
Clean up code and menus
Updated the Menus
Added the Raised Panel Geometry and Layers
Added Tool Profile Selection (Defaults Menu - You can select a Ball Mill, End Mill or V-Bit as the default bit profile)
Added New Tool Selection Menu
Added Make Toolpath Functions for the Geometry
Updated the User guide
SDK Note: The SDK "Create Toolpath Function" only supports the Ball Mill, End Mill and V-Bit's as usable profiles. To use other bits (Form Tool, Radiused End Mill, etc...) to create the milling, you will need to change the bit in the Toolpath. I have sent a request to the Dev team to add the other bit profiles to the Create Toolpath Function.
Please leave me some feedback . I hope you find it useful.
What is New
Updated the Menus
- (1.49 MiB) Downloaded 174 times
- EasyMDFDoorMaker_Ver10.7.pdf
- (1.63 MiB) Downloaded 149 times
Jim
Jim
- Model of CNC Machine: Shapeoko 3D XXL
So Do I need to download yet another version listed above.
thanks Jeff Peters
thanks Jeff Peters
any chance that there can be a video made showing how to use the program from from start to finish.with toolpaths shown
Jeff Peters
Jeff Peters
- jimandi5000
- jimandi5000
Hello All,
Making a "How To Use" video, and found an issue with the Easy MDF Door Maker. I have fixed the issues and added the milling option to mill the door in a Flat or in a Raised panel style.
Version 10.8
What is New
Updated the Main Menu
Added Raised Panel
Fixed some code
Please leave me some feedback. I hope you find it useful.
Version 10.8
What is New
Added Raised Panel
Fixed some code
- (1.76 MiB) Downloaded 152 times
- EasyMDFDoorMaker_Ver10.8.pdf
- (1.93 MiB) Downloaded 157 times
Jim
Jim
- BenjaminwithCNC
- Model of CNC Machine: Danibrum 1325 ATC Rotary 4x1
Hello Jimandi.
It took me some time to test and to get myself informed about the Scribe Lines. For them to look good, and to be correct, they are not allowed to be 4 lines in each Scribe Corner, but 2 Lines that go like this: Left one from Top to Bottom and the Right one from Bottom to Top.
I'm sorry for the late Answer but it took me some while.
Benjamin
Benjamin
- jimandi5000
Hello All,
Made the Scribe change and it should work this time.
Version 10.9
What is New
Updated the Default Menu
Added Select number of Scribe Lines per Door
Version 10.9
What is New
- (1.76 MiB) Downloaded 182 times
- EasyMDFDoorMaker_Ver10.9.pdf
- (1.71 MiB) Downloaded 182 times
Jim
Jim
- sharkcutup
You might want to check this too!!! Version 10.7 if you haven't already fixed it!!!
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
- jimandi5000
Hello All,
I have fixed the "X" button to remove a selected tool.
Thank you Sharkcutup!
Version 11.0
Version 11.0
Jim
Jim
- sharkcutup
Nope Vertical Scribe is the same!!! They need to be in opposite directions in order for toolpath to work correctly.
Be sure to look into my problem noted previous also in relations to the last Tool removal button. Thanks!!!
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
- jimandi5000
Hello All,
Version: 11.0
Version: 11.0
- (1.76 MiB) Downloaded 149 times
Jim
Jim
- sharkcutup
Have another Suggestion for you!!! Add Box Core bit to selections where Ball Nose bits are used (EX: Panel Forming). They make nice inside radius edges too!!!
Just a Thought!!!
Sharkcutup
Just a Thought!!!
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
