Easy MDF Cabinet Door Maker
sharkcutup
Re: Easy MDF Cabinet Door Maker
Post by sharkcutup »
Hi Jim -
I'm receiving a "No layer found with name = Door Scribe Lines" and "Door Flutes" with the attached settings. Though as far as I can tell, I'm not missing a toolpath or any design element.
Have I misinterpreted a setting/tool usage, perhaps? Thanks for the gadget and any help you can provide!
Those messages are shown whenever you do not choose to have Scribe lines and Door Flutes on your doors. I usually just ignore those messages because I understand the gadget entirely to well now.
I noticed that you are using 11.7 Version of the Gadget. According to this thread 11.9 is the most recent from Jim.
Sharkcutup
V-Carve Help is Available!!!
Private Message Me!
V-Carve Pro 11.504
sharkcutup
Hello All,
I have been busy BETA TESTING and updating the Easy Door Maker Gadget. Found a few Issues and fixed a few issues recommended by other users of the gadget.
What is New:
• Fixed Oval Door with Crossing Flute Lines Hiccup --- variable "pty" was not recognized
• Fixed Double Arch Hiccup -- Second panel was not being created when creating doors up in length (say a 57" door)
• Standardized Flute and Fluting to "Flute"
• Standardized Inter to "Inner".
• Added note to "Inside Edge Milling" on User Interface.
• Added note to "Divider Width" on User Interface.
• And there are too many changes for me to remember them all.
Version 12.0
The Easy Install Steps:
1. Download the gadget EasyMDFDoorMaker.zip that is attached to this post.
2. Rename it from EasyMDFDoorMaker.zip to EasyMDFDoorMaker.vgadget
3. In Vectric Pro, Aspire, or Cut2D Pro click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it and click Ok.
If successful, a pop up saying the gadget was installed and you should see EasyMDFDoorMaker is now in the Gadgets menu.
EasyMDFDoorMaker12.0.zip
(1.71 MiB) Downloaded 143 times
Rename to: EasyMDFDoorMaker12.0.vgadget
Please leave me some feedback . I hope you find it useful.
Sharkcutup (with permission From Jim Andi5000 of Jim Andi Gadgets)
Private Message Me!
V-Carve Pro 11.504
sharkcutup
Correction ---
Arched Style Hiccup --- Second panel was not being created when creating doors up in length (say a 57" door)
Sharkcutup
Private Message Me!
V-Carve Pro 11.504
Tvister
Model of CNC Machine: CanCam C2-510ATC
Post by Tvister »
Hey what a great gadget!!!
Would it be possible to add a feature for automatic rounded profile corners on the doors?
jimandi5000
Post by jimandi5000 »
Tvister wrote:
Mon Dec 05, 2022 11:34 pm
Sure, I can do that.
How this works is you post a drawing of what you are thinking about and I will add options to the gadget to add it.
Jim
adze_cnc
Post by adze_cnc »
Hello Jim,
A trivial error found around line 1126 of EasyMDFDoorMaker_Ver12.0.lua:
Code: Select all
  Pdialog:UpdateLabelField("Door.Alert", "")
  if Door.Count < 1 then
    Pdialog:UpdateLabelField("Door.Alert", "Error: Door Count Required")
  elseif Door.Count < 1 then
    Pdialog:UpdateLabelField("Door.Alert", "Error: No Door Count Provided")
The "elseif Door..." line is a duplicate of the "if Door..." line and will never evaluate to true.
sharkcutup
adze_cnc wrote:
Tue Jan 10, 2023 12:26 am
Hello Jim,
Code: Select all
Thank You, Stephen !!! :D
I have reviewed this item and it will be resolved in an updated version (whenever that may be).
Sharkcutup
Private Message Me!
V-Carve Pro 11.504
jimandi5000
Hello Jim,
Code: Select all
Thanks for finding this and showing it to us. Yep, I had duplicated the error trap to prevent some other poetical issue and should have removed the duplicated code. The user will never see the second message so it will be removed on the next release.
Thanks again! :)
Jim
