Hello All,
I have received a request to provide a set of the Easy Gadgets that will run on older versions (pre version 10.0) of Vectric software VCarve Pro and Aspire. Going forward I will use the Gadget Name to identify the version the gadget will support as shown below:
EasyCabinetMaker09-7.2.lua - Will run on versions below 10
EasyCabinetMaker10-7.2.lua - Will run on version 10 and up
I will use this post to place them:
Here is the EasyCabinetMaker09-7.2 Gadget and the others Easy gadgets will be coming soon.
Easy Gadgets for Pre Version 10
- jimandi5000
- EasyCabinetMaker09-7.2.zip
- Rename to EasyCabinetMaker09-7.2.vgadget
- (37.71 KiB) Downloaded 186 times
Jim
Jim
- jimandi5000
Re: Easy Gadgets for Pre Version 10
Here is the Easy Drawer Maker Gadget
- EasyDrawerMaker09-2.1.zip
- Rename to EasyDrawerMaker09-2.1.vgadget
- (27.44 KiB) Downloaded 173 times
Jim
Jim
- jimandi5000
Here is the Easy Dovetail Maker Gadget.
- EasyDovetailMaker09-5.5.zip
- Rename to EasyDovetailMaker09-5.5.vgadget
- (26.28 KiB) Downloaded 181 times
- EasyDovetailToolDatabase09-2.5.zip
- Rename to EasyDovetailToolDatabase09-2.5.vgadget
- (27.22 KiB) Downloaded 175 times
Jim
Jim
- jimandi5000
Here is Easy Box Joint Maker Gadget
- EasyBoxjointMaker09-3.3.zip
- Rename to EasyBoxjointMaker09-3.3.vgadget
- (15.93 KiB) Downloaded 187 times
Jim
Jim
- jimandi5000
Here is Easy Euro Hinge Maker Gadget.
- EasyEuroHingeMaker09-4.02.zip
- Rename to EasyEuroHingeMaker09-4.02.vgadget
- (51.54 KiB) Downloaded 185 times
Jim
Jim
- jimandi5000
Here is the Easy Bottle Carrier Gadget.
- EasyBottleCarrier09-4.0.zip
- Rename to EasyBottleCarrier09-4.0.vgadget
- (17.25 KiB) Downloaded 171 times
Jim
Jim
