Easy Dovetail Maker 4.0
jimandi5000
Post by jimandi5000 »
Hello All,
I have completed the Easy Dovetail Makers Gadget. Please see the files below.
I will try to post a video in how will it makes dovetails in the next day or so.
Please let me know if you have any issues using the gadget.
Have fun.
Easy Dovetail Gadget Development Ver4.0.pdf
(2.18 MiB) Downloaded 36 times
EasyTools20200513a.zip
(2.41 MiB) Downloaded 32 times
Jim
gkas
Re: Easy Dovetail Maker 4.0
Post by gkas »
That looks great... Now all I need is a way to hold boards vertical in my CNC.
scotttarnor
Model of CNC Machine: Piranha XL , Shark HD520
Post by scotttarnor »
Very nice ! I just need to come up with some time to try it !
Thank You for making this !
Scott T
jimandi5000
gkas wrote:
Thu May 14, 2020 7:24 am
Hi GKAS,
Thanks! I hope you can get some use out of it. :)
Jim
jimandi5000
scotttarnor wrote:
Thu May 14, 2020 12:12 pm
Hi Scott,
Thank you. I plan to get in the shop and see if I can make some dovetail joints today.
Jim
jimandi5000
Hello All,
I hope are doing well today.
I just completed my test run of the Easy Dovetail Maker. Have a look at the video.
Notes:
1. I had 0.010 inch entered in the Fit Adjustment value. I am thinking I can drop that down to 0.003 on the next test or may need to go to -0.003.
2. I did not have the Origin Point correct. I see the joint is not 100% centered.
https://youtu.be/uEB6omzgWVY (4 minutes)
Let me know your thoughts.
Jim
BillK
Model of CNC Machine: CNC Shark Pro Plus
Post by BillK »
Hi Jim,
Watched your video. That’s exactly the way I did it the very first time I cut dovetails on my CNC. So I should tell you that you made the same mistake I did. Traditionally dovetails are always cut with half a pin on the outside. You cut yours (as I did) with half a tail on the outside. I think the reason is if you make them by hand a half tail is more likely to cause a split on the board than half a pin. I have now always made mine the traditional way with half a pin on the outside. Check any furniture you have with dovetails and the pins will be on the outside.
BillK
https://www.facebook.com/CarvingsByKurtz
jimandi5000
Correct layout
Correct layout
I need to change the code.
Jim
BillK
Post by BillK »
Sorry about that.
BillK
jimandi5000
HI Bill,
No, No, No... Thank You! I am very happy that you told me about the issue. I need and want the feedback from the team. I would hate to put something out there an no one use it because it was not working correctly.
Again, Thank you for the feedback.
Jim
BillK
Post by BillK »
jimandi5000 wrote:
Fri May 15, 2020 5:28 pm
HI Bill,
You’re welcome! On your original post, your image shows the joint the traditional way, so unless you made the video, I probably wouldn’t have noticed until I tried it.
BillK
