Easy BoxJoint Maker 3.2
jimandi5000
Post by jimandi5000 »
Hello All,
I hope you and your family are in good health.
I was making some boxes on the mill using the Easy Box-joint Gadget 3.0. After cutting a few, I found I needed to add some relief cuts to each side of the board to prevent tearout. I went ahead and updated the code to Version 3.2 and now it adds a gentle relief on each side of the finger joint. Please review and let me know if you find any issues.
I'm getting bored sitting around so I'm gonna ask, are there any request out there for a Gadget?
I believe these pictures should be self explanatory, but if you have questions don't hesitate to let me know.
EasyTools-04-30-2020.zip
This zip file contains all of the most current Easy Gadgets versions.
(205.48 KiB) Downloaded 47 times
Jim
AcBCDN
Model of CNC Machine: HomeBuilt
Re: Easy BoxJoint Maker 3.2
Post by AcBCDN »
It works!! But I always have to remove
Code: Select all
require("mobdebug").start()
Rather than commenting it out is there a download or setting so the nil error doesn't show up.
jimandi5000
Hello All,
Here is Version 3.3
I was running the Box Joint Gadget today and found I needed to add clearance value to adjust the fit of the joint.
Fixed:
1. Commenting out debug code (Thanks AcBCDN)
2. Added the Clearance function (+ or - values) and made updates to Dialog (see picture below)
3. Incremented the Version number
Next Step:
1. Make a video on how to use the Gadget
2. Write the Help File
Have a look and let me know.
EasyTools_05012020.zip
All Easy Gadgets
(206.03 KiB) Downloaded 58 times
Version 3.3
Version 3.3
Jim
AcBCDN
Post by AcBCDN »
Good addition. Thanks again for all the effort into this.
jimandi5000
Okay! :)
I have a help document for Version 3.3
Please let me know if you see any issues.
I don't think I need to make a video now but please let me know if you think I should.
http://www.jimandi.com/FileShare/BoxJoi ... Ver3.3.pdf
Making Chips :)
Making Chips :)
Jim
Post by mtylerfl »
Very cool, Jim! (I like your VGM, too!)
jimandi5000
Thanks! I also posted the Help File to the WiKi
The Help Button point the the Wiki
Jim
jimandi5000
The Easy Box Joint Fit Video! (20 Seconds) :D
https://youtu.be/BleZzUytb_A
Jim
Post by mtylerfl »
jimandi5000 wrote:
Sat May 02, 2020 9:38 pm
It fits! :D
jimandi5000
mtylerfl wrote:
Sat May 02, 2020 9:41 pm
It fits! :D
I will not say how much wood I used to make it work. :)
Jim
BillK
Model of CNC Machine: CNC Shark Pro Plus
Post by BillK »
A sliding dovetail joint gadget would be nice to have. It’s a great joint and easy to cut once you figure it out.
BillK
https://www.facebook.com/CarvingsByKurtz
jimandi5000
BillK wrote:
Sun May 03, 2020 3:02 pm
hi Bilk,
I can do that! I am about to complete the Dovetail Gadget, I am about 95% done. I as soon as I am done I will bang one out for you to test drive. :)
Jim
