Easy BoxJoint Maker
cusoak
Re: Easy BoxJoint Maker
Post by cusoak »
The CNC I have, the router will go past the front of the frame allowing for a jig to be attached.to it
This would allow for wood to clamped wood in the vertical position and cut box joints or dovetail joints on the end of a board.
Jeff
cusoak
Post by cusoak »
Jim Also where do I get the latest version and what do I need to do to install it
Thanks Jeff
jimandi5000
Post by jimandi5000 »
jimandi5000 wrote:
Sat Apr 25, 2020 5:32 am
cusoak wrote:
Fri Apr 24, 2020 3:15 pm
Would your box joint creator gadget before cutting joints vertically over the front of aCNC.
I sure hope so.
If so where can I get the latest version
Thanks JeffPeters
I am sorry, I don't understand the question?
Here is the last update to the Easy Gadgets - download/file.php?id=71312
Let me know if you have any questions.
Jim
cusoak
Post by cusoak »
Well Jim I downloaded the file and installed it
But I can't get it to figure out how to use it.
So I did the job set up then the boxmaker screen come up with numbers in all 3 of the boxes if I try to change any of them another screen come up that says Default Contents.
So what am I doing wrong
I used o.65 for X
5.0 for Y
and 10.75 for Z
a video on how to use it would be great.
Thanks Jeff
jimandi5000
cusoak wrote:
Sun Apr 26, 2020 2:13 pm
I used o.65 for X
5.0 for Y
and 10.75 for Z
Thanks Jeff
Hi Jeff,
I made some Box-Joints the other day and the Mill is still setup so I will make a video on how to use the Gadget and how the material is positioned and cut. He made any day or so to get a tripod and some lighting in the shop but I will do my best to get it done this week.
Thanks!
Jim
cusoak
Post by cusoak »
Jim That would be great.
Thanks Jeff
cusoak
Post by cusoak »
Here is an error message when I open the box creator file
What do you make of this.
i would like to do some boxes using you gadget but need some help figuring out how to use it.
Thanks Jeff
cusoak wrote:
Sun May 10, 2020 1:10 pm
Thanks Jeff
That's a different gadget. Jim's is the BoxJointMaker not Box_Creator.
That error message is from the Box Creator gadget on the Vectric gadgets page and you're getting that error because you've installed the wrong version for the version of VCarve you have.
The correct download for your version is here - http://gadgets.vectric.com/V10/box_creator.html
