Easy BoxJoint Maker
jimandi5000
Easy BoxJoint Maker
Post by jimandi5000 »
Hi All,
I have upgraded the BoxJoint Maker 2.0 to run under Version 10+.
Have a look.
Working on the Help File and I may do a video to show to use the gadget. Thoughts?
BoxjointMaker.zip
(19.4 KiB) Downloaded 111 times
Jim
AcBCDN
Model of CNC Machine: HomeBuilt
Re: Easy BoxJoint Maker
Post by AcBCDN »
A couple of things. Had to comment out the debug command before it would run
The error below shows up when I launch the gadget.
The second error show up when I click to to execute.
I must be doing something wrong?
Andy
jimandi5000
Thanks for the feedback... here is 2.01. The error was a type-o.
On the first message box, have a look at the job setup picture Caption4.JPG. This gadget mills on the end of the broad. So, the job X and Y set the broads thickness and width. The job Z is the broad length.
BoxjointMakerVer2.01.zip
(19.4 KiB) Downloaded 89 times
Jim
AcBCDN
Post by AcBCDN »
Hi Jim,
It worked!!
I flipped x and y around for the thickness of the material. So a my choice of board orientation can be along x or y. I have not setup my CNC for vertical milling yet so I wanted to make sure I had that option.
Thanks again for your gadget creations.
Andy
jimandi5000
AcBCDN wrote:Hi Jim,
It worked!!
Andy
Jim
rdean33422
Model of CNC Machine: RF31, 4X8 Router both CNC
Post by rdean33422 »
Jim
I keep getting a "nil" error when I try to run either Version 1 or 2.
I am sure it is something I am doing wrong but I don't have a clue.
Ray
jimandi5000
rdean33422 wrote:Jim
Ray
Hi Ray,
Can you do a full screen capture with the error and post it here?
Jim
AcBCDN
Post by AcBCDN »
I have to comment out the
Code: Select all
require("mobdebug").start()
to
Code: Select all
-- require("mobdebug").start()
line.
rdean33422
I have this but not full screen yet. Any help?
Ray
jimandi5000
Looks like I did not save the file when I fixed that. I I have made a number of changes to the code, I will post a new version.
Jim
AcBCDN
Post by AcBCDN »
jimandi5000 wrote:Looks like I did not save the file when I fixed that. I I have made a number of changes to the code, I will post a new version.
I always look forward to what new fixes you bring.
Thanks again!!!
rdean33422
Jim
I modified the lua file to read "-- require("mobdebug").start()" and it now works fine.
I have been making these joints for some time by drawing them out in Aspire which is time consuming and sometimes frustrating.
This will make things so much easier for me.
Thank you very much!
Ray
jimandi5000
Hello All,
I have fixed/added some changes to the EasyBoxJoint gadget:
1. More Error trapping
2. Supports all Vectric versions (I have no way to test below version 10. I need some help on testing). Code checks what version Vectric version is running and offers tool selection from the tool-database menu, if version is greater or equal to version 10.0 and if not, offers the user to enter the End Mill diameter value and bulds the toolpath. (see images below)
3. Added a WorkList .txt file on what I am doing next on the Gadget.
4. Checked "every gadget" in the zip file for: Displays menu correctly; Turned off the debug calls; Added Versions numbers to the names; etc...
5. Building out a format for both Written Docs (in Gadget folder) and Video (on YouTube) How to Run Gadget.
6. As well as, 1.2 million other things ;)
Please let me know if you see any issues.
If you are running below Version 10
If you are running Version 10 or Higher
EasyTools.zip
Contains All Easy Gadgets
(150.35 KiB) Downloaded 108 times
Jim
cusoak
Post by cusoak »
Would your box joint creator gadget before cutting joints vertically over the front of aCNC.
I sure hope so.
If so where can I get the latest version
Thanks JeffPeters
jimandi5000
cusoak wrote:
Fri Apr 24, 2020 3:15 pm
I sure hope so.
Thanks JeffPeters
I am sorry, I don't understand the question?
Jim
