Easy US Flag Maker
- jimandi5000
Re: Easy US Flag Maker
Hi Scott,
I am not finding any issue with the flag gadgets. Here is a copy of all my flag gadgets.
- EasyFlagMaker.zip
- Rename to: EasyFlagMaker.vgadget
- (192.32 KiB) Downloaded 177 times
Jim
Jim
- scotttarnor
Thank You for taking your time with this. I will have to figure out what is going on with my computer! I tried to record a little video to show what I see. (well I misunderstood the app, it is actually a series of screen shots).jimandi5000 wrote: ↑Sun Aug 22, 2021 3:38 pmHi Scott,
I also need to find out why the gadgets show up in the gadget menu but not in the data folder, I want to delete them and start clean but I can not locate them.
Again Thank You for your time, I will put this aside for now and try to figure it out later.
- i am a mess.zip
- (1.59 MiB) Downloaded 143 times
Scott T
@scottscnc
@scottscnc
You're probably looking in the wrong folder. Vectric gadgets that come with the program are installed in "c:\ProgramData\Vectric\{program}\{version}\Gadgets"scotttarnor wrote: ↑Sun Aug 22, 2021 4:56 pm
Third party and optional gadgets are installed to "C:\Users\Public\Documents\Vectric Files\Gadgets\{program} {version}"
- jimandi5000
Hi Scott,
My may want to look in these two locations:
1. C:\ProgramData\Vectric\VCarve Pro\V10.0\Gadgets
2. C:\Users\Public\Documents\Vectric Files\Gadgets\VCarve Pro V10.0
I hope this helps.
I hope this helps.
Jim
Jim
- scotttarnor
Thank you Adrian and jimandi5000, I will look when I get home later tonight.
Scott T
@scottscnc
@scottscnc
- scotttarnor
Well my old laptop with windows 7 just does not like the gadget in Aspire or Vcarvepro, I have tried everything I can think of and suggested
( new install of Vcarvepro, delete old flag gadgets, automatic install, manual install) but nothing has worked.
The first pop up window opens up a blank box and when I hit enter it tells me to enter a number.
But window is blank so I can't , I did randomly try entering a number with no luck.
It does work on my Mac running parallels so I do have a work around.
Scott T
@scottscnc
@scottscnc
- jimandi5000
Hi Scott,scotttarnor wrote: ↑Mon Aug 23, 2021 3:20 pmWell my old laptop with windows 7 just does not like the gadget in Aspire or Vcarvepro, I have tried everything I can think of and suggested
Can you run any other gadgets?
Jim
Jim
- scotttarnor
Yes I have tried a couple of the “preloaded” gadgets and they worked, I also use tailmakers puzzle gadget. I do not have any antivirus on this machine, not sure if that would matter.
Scott T
@scottscnc
@scottscnc
- jimandi5000
Hi Scott,scotttarnor wrote: ↑Tue Aug 24, 2021 12:04 amYes I have tried a couple of the “preloaded” gadgets and they worked, I also use tailmakers puzzle gadget. I do not have any antivirus on this machine, not sure if that would matter.
OK... please load and run this test gadget.
1. Download the test Gadget to your "Download Folder" and do not move it.
2. Rename the file to "MyTest.vgadget"
3. Open V-Carve Pro or Aspire and pull down the Gadgets menu.
4. Select "Install New Gadget..."
5. Navigate to your "Download Folder" and select the "MyTest.vgadget" file
6. You should receive confirmation of new gadget added.
7. Pull down the Gadgets menu and you should see "MyTest" available.
8. Run the gadget and tell me what you see
- MyTest.zip
- Rename to: MyTest.vgadget
- (250 Bytes) Downloaded 135 times
Jim
Jim
- scotttarnor
I will do this when I get home tonight(2nd shift).
Thank you again for all the work you do!
Scott T
@scottscnc
@scottscnc
- scotttarnor
Tried all the gadgets and flag tried your new version 4 and global settings were the 2 that do not work for me on this machine
Scott T
@scottscnc
@scottscnc
- jimandi5000
Hi Scott,
What are you running as a web browser?
Have you removed IE from your pc?
Jim
Jim
- scotttarnor
- jimandi5000
- scotttarnor
jimandi5000, I do appreciate all the assistance you did provide trying!
Thank You !
I will use my Mac to make the file then transfer it over the problem child. If I ever figure anything out I will let you know.
Thank You !
Scott T
@scottscnc
@scottscnc
