Easy Cabinet Maker
jimandi5000
Re: Easy Cabinet Maker
Post by jimandi5000 »
dyn0bill wrote:
Fri Feb 26, 2021 5:41 am
Where do I get the latest rev of Easy Cab?
Thanks :?:
This Version is for Version 10 or higher of Vectric?
EasyCabinetMaker10-8.1.zip
Rename to EasyCabinetMaker10.vgadget
(37.99 KiB) Downloaded 35 times
Jim
jimandi5000
Hello All,
I have made an update to the Easy Cabinet Maker. Version 10-8.2 has a new error trap. if the user forgets to select a Project Path, the error trap will prompt the user with a dialog box for the user to enter the Project Path or navigate to it. this will allow the gadget to run.
Your feedback is welcome.
:D
EasyCabinetMaker10-8.2.zip
Rename to EasyCabinetMaker10-8.2.vgadget
(39.53 KiB) Downloaded 36 times
Jim
PRO4824
Model of CNC Machine: AVID PRO4824
Post by PRO4824 »
That's a great gadget. When you get to the final update, it'll be time to start working on the Easy car audio Speaker Box maker! 🙂👍
Isaiah 41-10
jimandi5000
PRO4824 wrote:
Wed Mar 10, 2021 3:55 am
Sure thing!!! do you have a drawing of the speaker box? :)
Jim
PRO4824
Post by PRO4824 »
No Sir, I don't make them but it's a big industry for cnc owners to get into.
If I had a cool gadget, I might start. 😁
Isaiah 41-10
dyn0bill
Model of CNC Machine: EZ Route 4x8
Post by dyn0bill »
Thanks for the update. I put all my info in to do a 11" wide wall cabinet. When I tell it "OK" it goes away and nothing happens? Do I not have it installed correctly?
jimandi5000
dyn0bill wrote:
Thu Mar 11, 2021 5:17 am
Can you post a screen shot of the main screen showing the cabinet size? I tried it and it worked fine for me.
Jim
dyn0bill
Post by dyn0bill »
Thanks Jim,
Just for a hoot I deleted the registry key and ran it with the defaults and it worked. I will try the 11" wide this evening and see what happens.
What is the best way to remove and install your gadget?
Willy
dyn0bill
Post by dyn0bill »
A couple of screen shots. My setup and after I press the "OK".
I zoomed out.
I zoomed out.
jimandi5000
dyn0bill wrote:
Fri Mar 12, 2021 2:00 am
What version are you running?
it works for me...
it works for me...
Jim
dyn0bill
Post by dyn0bill »
Jim,
Would you send me the 11" crv file? My material is 1/2". I still can't get it to work. How do I completely remove it and try a reinstall?
Willy
jimandi5000
dyn0bill wrote:
Sat Mar 13, 2021 4:05 am
Jim,
Willy
Hi Willy,
I found the error. Can you try this link to the download page?
http://www.jimandi.com/EasyGadgets/Easy ... Maker.html
please let me know.
Jim
dyn0bill
Post by dyn0bill »
Thanks Jim,
It is working!
My CNC cutting bed is 48 wide by 96" tall. How do I tell Easy Cabinet to rotate 90 degrees +/-?
Is the only option to do it manually?
Willy
48x96
48x96
jimandi5000
dyn0bill wrote:
Sat Mar 13, 2021 6:57 am
Thanks Jim,
It is working!
Yes, you need to do it manually but I can add that to the code.
Give me some time to figure it out.
Jim
jimandi5000
Thanks Jim,
It is working!
Jim
