Easy Cabinet Maker
cusoak
Re: Easy Cabinet Maker
Post by cusoak »
Also which version do I want to down load for version 10. VCP
Jeff
MustStayBusy
Model of CNC Machine: Avid CNC 5x5 pro
Post by MustStayBusy »
Bug report - I testing version 7.2 and when selecting tools, if the tool name is longer than the dialog box, it removes the TOOL button and you can no longer select any tools.
jimandi5000
Post by jimandi5000 »
MustStayBusy wrote:
Mon Jan 18, 2021 2:09 am
Thanks! I will fix that ASAP.
Jim
Ken Rychlik
Model of CNC Machine: Buy, fix, and sell them
Post by Ken Rychlik »
Jim, I'm glad to see your still running with the idea.
Custom CNC Work
Local Machine Repairs and Programming
jimandi5000
jimandi5000 wrote:
Mon Jan 18, 2021 4:01 am
Okay, did a deep dive on the code. If you select a tool with a name that is longer than the display currently can display, the select button is pushed to the right as show in image below. To fix this, select and slide the edge of the dialog to the right to show the buttons.
Jim
MustStayBusy
Jim, thanks for that. I missed that I could resize.
MustStayBusy
Jim,
A couple of questions:
Is there a way to set default tools?
It looks like all of the wizard settings get stored in the windows registry. So if I wanted to go back to a different cabinet design and make small changes and let the widget rebuild the cabinet, it appears that I would have to re-enter those settings. Is there possibly a way to write that in the DAT file so we have record of the settings or am I missing something?
For the wall cabinets in my shop, I like using french cleats, is there a way to add in that as an option in the gadget?
Thank you for building this gadget!
jimandi5000
MustStayBusy wrote:
Sun Jan 24, 2021 6:34 pm
Jim,
Thanks for the feedback.
Let me see if I can do that.
Jim
jimandi5000
Well, I have been trying to save the tooland recall the tool. Have not been successful. Anyone have thoughts?
Jim
ORcoastCNC
Model of CNC Machine: AvidCNC Pro 4896
Post by ORcoastCNC »
Quick question about Easy Cabinet installation. I've installed it both by renaming the .zip and moving the .lua file to the gadgets folder in Aspire (running current Aspire 10.512 on Windows 10 current update), but I keep getting this notice:
Alert: The CabinetMaker program has not been set up on this computer. The Project path must be selected and saved.
I can do paths in my sleep on Linux, but it seems not on Windows. Not sure what I am missing. The current path for all gadgets is:
C:\\Users\Public\Public Documents\Vectric Files\Gadgets\Aspire V10.5
What am I missing? Is there a program installation I don't have but need, or is that just a bug? Once I close the alert I can use the dialog boxes and inputs, and they all seem to work ok, I'll just get the same alert when I close the gadget boxes.
Thanks in advance for any help.
ORcoastCNC
Sorted it out...just hadn't looked far enough in the dialogues to see I needed to set up a project path, and that's what the alert was referring to. All's well!
dyn0bill
Model of CNC Machine: EZ Route 4x8
Post by dyn0bill »
Trying to run Easy Cab maker in VCarve Pro.Ver 10.512. I receive an error concerning toolpath generation? Don't know enough about Easy Cab to troubleshoot it.
Thanks for your help!
NJBOOST
Model of CNC Machine: Zenbot 48"48"
Post by NJBOOST »
i finally got a version 7.2 to work However once I try to load Drawermaker I get an error that says Lne 912 (global cutlistWriterHeader) attempt to index local 'file' (a nil file),
Vaughn
jimandi5000
NJBOOST wrote:
Tue Feb 23, 2021 1:13 am
Vaughn
Let me have a look... :)
Jim
dyn0bill
Post by dyn0bill »
Where do I get the latest rev of Easy Cab?
Thanks :?:
