Easy Cabinet Maker
jimandi5000
Re: Easy Cabinet Maker
Post by jimandi5000 »
conifer wrote:I'm using version 5.2 I don't get a face-frame cut list. But I do get the same overlap as dah79.
Hi conifer,
Two questions:
1. what version of the Vectric software are you running?
2. have you set the Project default path?
Looking forward to hearing from you. :)
Jim
cusoak
Post by cusoak »
Sorry I just found this a little to late. I just finished doing 10 cabinets for a customer.
So is this a gadget for vcarve pro if so where do I get the latest version of it and is there some instructions on how to use it.
I will sure try this out I have an island to build.
Thanks Jeff Peters
seminole`191
Model of CNC Machine: bobs e3
Post by seminole`191 »
Hello I downloaded the file but can't get it to install in aspire.It say "no items match your search". The "LUA" file isn't a recognized file. How do I get this to work? TIA
jimandi5000
seminole`191 wrote:Hello I downloaded the file but can't get it to install in aspire.It say "no items match your search". The "LUA" file isn't a recognized file. How do I get this to work? TIA
Hi Seminole,
I do not have Aspire, but if you rename the EastCabinetTools.zip file to EastCabinetTools.vgadget Then use the "Install New Gadget" function under the Gadget drop down menu.
Jim
wolfeman
Model of CNC Machine: Xcarve
Post by wolfeman »
I love all your gadgets. Thanks you so much for helping out so many people. One question on the cabinet maker. Can you add tabs somehow, just a thought. I will not be using this app but I think it might be handy. I do things like a cabinet but only once in a while and use a table saw. Thanks again for all your Gadgets !!!!!!!!
jimandi5000
wolfeman wrote:I love all your gadgets. Thanks you so much for helping out so many people. One question on the cabinet maker. Can you add tabs somehow, just a thought. I will not be using this app but I think it might be handy. I do things like a cabinet but only once in a while and use a table saw. Thanks again for all your Gadgets !!!!!!!!
Hi wolfman,
Can you provide more info on the Tabs? I am not clear yet.
Jim
wolfeman
Post by wolfeman »
Hey Jim, after cutting out the square boards can tabs be put along the sides so they do not move. Is that something that can be done in Regular Vectric or would it have to be put into the Gadget, If someone had a cutter beg enough to cut out several parts at one time. I do not know how Vectric and Gadgets interact with each other. If tabs could be add through vectric during the Gabinet Gadget was done there there is no big deal. Long counter top but want to cut as one long piece then split where tabs are rather then a lot of small cut out pieces. Just a though. No big deal.
jimandi5000
wolfeman wrote:Hey Jim, after cutting out the square boards can tabs be put along the sides so they do not move. Is that something that can be done in Regular Vectric or would it have to be put into the Gadget, If someone had a cutter beg enough to cut out several parts at one time. I do not know how Vectric and Gadgets interact with each other. If tabs could be add through vectric during the Gabinet Gadget was done there there is no big deal. Long counter top but want to cut as one long piece then split where tabs are rather then a lot of small cut out pieces. Just a though. No big deal.
Okay, I think I understand, holding tabs are usually added as apart of the tool path process. In the create toolpath menu, check the box and you can edit the amount and placement.
FYI. I know everyone may not have a mill that can handle full size sheet goods. You can still use the cabinet gadget. Run the gadget and build the cabinet. Print out the drawing and the bill of materials for a cut list. It should save you some time.
Jim
wolfeman
Post by wolfeman »
Thanks for the reply. I was not sure if the Cabinet maker included the tool path part or not, Now that I understand it makes since. :D .
jimandi5000
I can add it.. let me work on it and I will post a new version with tool paths.
Jim
jimandi5000
Hello All,
Here is Easy Cabinet Maker (Ver 6.32)
Here is what I have done:
1. More Error trapping
2. Cleanup of code
3. Rewrote all Dialogs
4. Fixed Layer Naming
5. Added toolpaths (Profiles, Pocketing, Drilling) If you do not select a drill, then the Hole Tool-path will not be made.
6. Added Smart Milling (only mill for the tools selected)
7. And 12M other items :D
PLease let me know if you see and issues.
Next steps:
1. Looking at making it Version Smart (if user is running older versions, then flip to old style tool database)
2. Build out the Help File
EasyCabinetMakerVer6.32.zip
(48.37 KiB) Downloaded 212 times
Jim
Beltramidave
Model of CNC Machine: FLA Saturn 4x4 / JTech 7W laser
Post by Beltramidave »
Euro hinge maker dialog box buttons not labeled or shown correctly. Latest version. Thanks for creating all of these gadgets.
Dave
https://lakesedgewoodcraft.com/
jimandi5000
dah79 wrote:Euro hinge maker dialog box buttons not labeled or shown correctly. Latest version. Thanks for creating all of these gadgets.
Okay, Let me have a look and see what I can find to fix.
Jim
jimandi5000
Hi Dah79,
Thanks for the feedback and here is Version 3.3 of Easy Euro Hinge Gadget.
I found and fixed these issues:
1. Better Error trap message on "No Job Setup"
2. Error trap Dialog for zero values
3. Error trap for "No door/box selected"
4. Dialog (CSS) display issues
5. And more code cleanup (I am learning so much doing these Gadgets)
Next Steps:
1. Add Toolpaths (Drill and Pocket)
2. Build a Help File or Video - What do you think would be better? (let me know)
EasyEuroHingeMakerVer3.3.zip
(4.52 KiB) Downloaded 141 times
Jim
Beltramidave
Thanks Jim. Works as expected now.
A help file is always good, but then so is a quick tutorial video. Thanks again for your continued gadgets!
Dave
