Easy Cabinet Maker
- jimandi5000
Re: Easy Cabinet Maker
Hello All,
Sorry for the delay, I was under the weather. But I found the issue and here is version 11.5 of Easy Cabinet Maker Gadget.
Supports: Vectric 10+
Have a look and let me know if you see anything.
- EasyCabinetMakerVer11.5.zip
- Rename to: EasyCabinetMakerVer11.5.vgadget
- (48.99 KiB) Downloaded 154 times
Jim
Jim
- sharkcutup
Good Job, Jim!!!
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- jimandi5000
- Model of CNC Machine: EZ Route 4x8/WinCNC
Thanks again Jimbo,
What other gadgets have you authored?
'til Valhalla,
Willy
'til Valhalla,
Willy
- jimandi5000
Hi Willy,
I do all of the "Easy" Gadgets.
Here is the list:
- Easy32mmSystem - produces a 32mm drill patter for European-style cabinets
- EasyBottleCarrier - produces a two-sided job for the creation of a bottle carrier based on user inputs (number bottles, bottle sizes, etc..)
- EasyBoxjointMaker - produces toolpath geometry to create box joints in a vertical orientation
- EasyCabinetMaker - produces a upper and lower cabinets with face frames and bill materials
- EasyCycloidMaker - produces a geometry "Cycloid" style arch
- EasyDovetailMaker - produces toolpath geometry for dovetail joints in a vertical orientation
- EasyDrawerMaker - produces geometry and toolpaths to produce (box joints) drawers
- EasyFencePostCapMaker - produces geometry and toolpath to produce a fencepost cap
- EasyFlagMaker - creates geometry for flags (24) I will add more if one is requested request
- EasyHingeMaker - produces door geometry and toolpaths for European-style door hinges (pocketed and screwed)
- EasyKeyholeMaker - added functionality to the current keyhole gadget (added slot Angle and slope
- EasyLockJointMaker - creates geometry and toolpath for a locking style joint
- EasyMDFDoorMaker - creates geometry for multiple styles of cabinet doors
- EasyZankMaker - creates toolpaths for the "Zank" inlay process
Jim
Jim
Holy Smokes Jimbo, you are the Big "Easy"!
Are these available to us peasants?
Willy
Willy
- jimandi5000
I would not say Big any more.... lost 160lbs I am still tall (6'-8") but not the "Big" person I once was...
Just look for the gadget name in the posting and download the newest version (last page)
Note: These are mostly for Vectric Pro and Aspire version 10+ this is due to the updates to the tool database in Version 10
Jim
Jim
Jimbo,
That weight loss is amazing! Are you done losing?
I have a gadget request. I am not sure what to call it but it is a box with partitions and can be wall mounted or with feet to be free standing.
Kinda like a dresser without the drawers.
Wall mounted or free standing compartments for storage.
Just thinking,
I could use a couple.
Willy.
Just thinking,
Willy.
- jimandi5000
Hi there sir,dyn0bill wrote: ↑Mon Oct 11, 2021 3:02 amJimbo,
Just thinking,
Willy.
On the weight thing, I had a life thing and I would not recommend it.
I would love to try to write you a gadget. Can you post a drawing or picture and I will have a look at it and the questions you would like the gadget to request?
Note: I do not charge anything for gadget writing. I am very slow and I use it to exercise my brain. We may have to make a number of versions until it works as you want.
Jim
Jim
Jimbo,
I did a little sketch in Sketchup and printed to a PDF. I didn't know if you could open a Sketchup file. Anyway, the attached picture shows what I was referring to concerning the gadget I would like.
It is not real simple. You would enter the length x width x height plus specifically what compartments you would like. Probably to start just make them all the same.
I also have a drawer in the picture. Maybe have the user answer a question about whether a drawer is wanted.
I am not explaining this very well but the picture should help.
'til Valhalla
WIlly
'til Valhalla
WIlly
- WallBox.pdf
- (290.48 KiB) Downloaded 129 times
- jimandi5000
Okay, let me have a look.dyn0bill wrote: ↑Tue Nov 02, 2021 6:33 pmJimbo,
'til Valhalla
WIlly
Jim
Jim
Just a quick question, is there any kind of tutorial for using this gadget? Great job making it, just need to know how to use it properly. Thanks!! Mike
Jimbo,
How are you?
Do you have any pictures of your machine? Mine is a homebuilt also.
'til Valhalla
Willy
How are you?
'til Valhalla
Willy
- Model of CNC Machine: ShopSabre Pro404
I cannot for the life of me get this gadget to work correctly. When I recalculate toolpaths I am always hit with errors and when I try to edit the toolpath with errors I get a message that tells me no valid data....
EDIT** I was able to do it finally and it would seem to be related to using the nesting function to reorganize the parts on the sheet. The profile cuts will recalc but the pockets do not.
- jimandi5000
Let me do some digging...mrramsey1969 wrote: ↑Sat Nov 13, 2021 1:32 pmI cannot for the life of me get this gadget to work correctly. When I recalculate toolpaths I am always hit with errors and when I try to edit the toolpath with errors I get a message that tells me no valid data....
Jim
Jim
