Easy Cabinet Maker
Re: Easy Cabinet Maker
Jim -
This worked fine on base 11. But upon migrating to 11.5, I'm receiving this message: Thoughts?
- sharkcutup
You need to have a job open in V-Carve Pro before you can use the Gadget.
A good Job Size 96.0" Wide by 48.0" Height Material thickness 0.75" and xy datum lower left corner. See Attached image. Then you can use the gadget.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- jimandi5000
Hi Sundown,
Let me do some testing under the new version 11.5
Thanks for the message.
Jim
Jim
Jim
Jim,
You might run the strict.lua from v11 and v11.5 through a file comparison tool (such as WinDiff in Windows) to see how they differ.
- sharkcutup
Sounds to me that not all the files associated to the gadget are in the folder for access.
You may want to reinstall gadget so that all files are installed where they need to be.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
- Model of CNC Machine: EZ Route 4x8/WinCNC
I can't seem to locate the Easy Cabinet Maker gadget download?
Where would I find it?
I looked in Gadgets.
Til Valhalla!
Til Valhalla!
As you might suspect from a forum named "User Submissions" these sorts of gadgets are only available here and not through official Vectric sites.
You can always find the latest copy by stepping backwards through the posts. The most recent of this gadget is a few pages ago. Here's a direct link.
These two posts might also with any installation problems:
post 1
post 2
post 1
post 2
- Model of CNC Machine: Yeti Smartbench
I can't seem to get it to load on, so must be a no then.jimandi5000 wrote: ↑Wed Oct 12, 2022 6:56 pmI am not 100% sure. You can try it and if it post an error, I can review the archives for an old version.
Looks like i'll be upgrading to the latest vcarve then.
What happens when you try to install?matt.albone wrote: ↑Sun Oct 16, 2022 9:47 pmI can't seem to get it to load on, so must be a no then.
Installs and loads fine for me in 10.5.matt.albone wrote: ↑Sun Oct 16, 2022 9:47 pmI can't seem to get it to load on, so must be a no then.
- sharkcutup
As I can recollect from all the Beta Testing I have performed ---- 10.0 and 10.514 worked fine then and 11.016 to 11.5 works fine Now.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
I cant get past the part where you re name the download. It doesnt show up when i click through the install gadget option.adze_cnc wrote: ↑Sun Oct 16, 2022 9:52 pmWhat happens when you try to install?matt.albone wrote: ↑Sun Oct 16, 2022 9:47 pmI can't seem to get it to load on, so must be a no then.
I've got 11.5 now so i'll see what happens.
- sharkcutup
I will Create a STEP by STEP Procedure with images for you.
Hope your not trying to install into Desktop because Desktop cannot use GADGETS!
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
No not using desktop, ive got the gadget working now thank you.
- sharkcutup
Great!!!
I will continue to create a Step by Step Process because it may help someone else out when installing any of the many gadgets available to V-Carve Pro and Aspire Users.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
