Easy Cabinet Maker
sharkcutup
Re: Easy Cabinet Maker
Post by sharkcutup »
adze_cnc wrote:
Thu Feb 02, 2023 7:38 pm
sharkcutup: file EasyCabinetWallVer14.9.xlua
approx. line 442
Code: Select all
CutListfileWriterItem(BOM.PID, "Left Side Panel","Wall", "1",
	WallDim.MaterialThickness, BOM.WallCabinetMateralType, BOM.WallCabinetFinish,
	WallDim.SidePanelWidth, WallDim.SidePanelWidth)
approx. line 583
Code: Select all
CutListfileWriterItem(BOM.PID, "Right Side Panel","Wall", "1",
	WallDim.SidePanelWidth, WallDim.SidePanelLength)
In 442 there is duplicate SidePanelWidth
Yup, already got it changed thank you. It will be out in the next version of the gadget which is undergoing beta testing at the present time.
Thank you again,
Sharkcutup
V-Carve Pro 12.004
aa1pi
Model of CNC Machine: KRMx01
Post by aa1pi »
Ver 14.9 Cabinet cut list ID 160 BACK PANEL MY CABINET HEIGHT IS 20" , the width the program gives is 17- 13/16 which is off, the length is ok 16-1/8
In the drawings the width is 18-13/16 .
jimandi5000
Post by jimandi5000 »
aa1pi wrote:
Sun Feb 05, 2023 12:51 am
Hi aa1pi,
Thanks for your note.
To really help you, I would need to understand your Cabinet design parameters.
Can you send me the following items?
1. Cabinet type ( wall or base )
2. The outer dimension height, width, depth
3. Face frame details ( side reveal, top reveal, bottom reveal, and all of the material widths for the face frame )
4. Plywood thicknesses and your preferred dado height value
5. Copy the drawing and bill of materials
Jimandi
Jim
aa1pi
Post by aa1pi »
Image[/img]
When I try to add a file the above line is the result.
It would be easier if I could upload files.
aa1pi
Post by aa1pi »
While waiting here is another error I found in the cut - list ID 180 and 190 need to be swapped in the drawing.
BLVWoodworking
Model of CNC Machine: DBC 5x8
Post by BLVWoodworking »
Jim,
Thank you for this incredible gadget! I very much appreciate the incredible effort you have put into this tool, unimaginable hours. Its very generous of you to share your skills with this community. Many thanks!! And a big thank you to Shark and others who have assisted!
I have just recently found this gadget and have been running it, testing it to see how it behaves, reverse engineering the formulas. I have feedback, questions and suggestions. I see that you have been actively addressing the same from others who have posted here. But before I presume you would be in a position to accept more work, this: Could I put together an organized document of feedback, questions and suggestions for you (and anyone willing) to take a look?
Thanks and kind regards,
Brian
aa1pi
Post by aa1pi »
1. Cabinet type ( wall or base ) ................ wall
2. The outer dimension height, width, depth ........20" 17-1/4 11 1/2
3. Face frame details ( side reveal, top reveal, bottom reveal, and all of the material widths for the face frame ) side 2.25 - 20 --0.75
top 1.75 -- 12.75 0.75 Bottom 1.25 12.75 0.75
4. Plywood thicknesses and your preferred dado height value 3/4 1/2
5. Copy the drawing and bill of materials ......cannot upload Admin could fix.
jimandi5000
aa1pi wrote:
Sun Feb 05, 2023 9:30 pm
Thanks for the data. I wish I could get a copy of the BOM files.
I did some math on a 20" wide wall cabinet and this is what I came up with.
Width - Left side reveal - dado height - dado height - Right side reveal = back panel Width
20" = 0.25" - 0.5" - 0.5" - 0.25" = 18.5"
This tells me I still need the cabinet design values. Do you see a Export setting button on the main screen? if you select the button the program will export all of the system setting to a .export file in the project location.
Is you post it in a zip file I will have what I need.
Jim
dyn0bill
Model of CNC Machine: EZ Route 4x8/WinCNC
Post by dyn0bill »
Dumb question,
Where do I download the gadget from? I can't seem to find it. The gadget forum does not have a download section.
Thanks for the help.
Willy
jimandi5000
dyn0bill wrote:
Mon Feb 06, 2023 4:51 am
Dumb question,
Willy
Hi Willy,
Can you hold off a day or so? We have version 15.3 in bata testing and the issues are getting smaller and fewer.
Please let me know.
Jim
aa1pi
Post by aa1pi »
Jim
The export is giving a warning and error.
V11.5 Easy..........\EasycabinetDialogVer14.9.xlua: variable 'NameValidater' is not declared.
dyn0bill
Post by dyn0bill »
No worries, I can wait.
sharkcutup
Jim you have posted most everything we need to help solve your issue except an image of your WALL cabinet settings. Please cluck on Wall Cabinet at Main interface/menu and post that screenshot.
Thank you,
Sharkcutup
V-Carve Pro 12.004
sharkcutup
sharkcutup wrote:
Mon Feb 06, 2023 8:41 pm
Thank you,
Sharkcutup
I am sorry not Jim I meant aa1 pi
aa 1 pi please post screenshot of Wall settings.
Sharkcutup
V-Carve Pro 12.004
aa1pi
Post by aa1pi »
Here is the wall cabinet settings
