Easy Cabinet Maker
- Model of CNC Machine: unkniwn
Re: Easy Cabinet Maker
Thanks for the gadget!! Two things, one you misspelled vgadget in your instructions on the part for how to install. Also I get the following error message.
nevermind.
- jimandi5000
- Model of CNC Machine: EZ Route 4x8/WinCNC
Jimbo,
How are you? I hope things are well with you.
Would you take a look at the attached file. I tried to create a cabinet that was tall an skinny. The first sheet looks good.
Til Valhalla
Willy
Til Valhalla
Willy
- refer6ft x12inches.zip
- Tall and skinny cabinet.
- (195.57 KiB) Downloaded 78 times
- jimandi5000
Hi Willy,
I looked at the drawing and the parts look correct. The only thing I see, the X and Y are flipped on the sheet size.
I will have a look and see what is happening in the code.
Thanks for showing me this.
Jim
Jim
- sharkcutup
Hey Jim,
I see the same Sheet 2, 3, 4 has flipped for some reason (Also noted dimensions of these sheets are far different from the first sheet too!)
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
- jimandi5000
Yep, I see in the code that the x and y are flipped. I should have a update tonight.sharkcutup wrote: ↑Mon Mar 28, 2022 8:19 pmHey Jim,
Sharkcutup
Jim
Jim
- jimandi5000
Hello CNC'er's,
I have fixed the Sheet size and part location issue.
Here is version 13.8 and will only work within version 11+ of the VCarve Pro or Aspire.
Supports:
Version 11+ VCarve Pro or Aspire.
The Easy Install Steps:
1. Download the gadget EasyCabinetMaker.zip that is attached to this post.
2. Rename it from EasyCabinetMaker.zip to EasyCabinetMaker.vagdget
3. In Vectric Pro or Aspire click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it and click Ok.
If successful, a pop up saying the gadget was installed and you should see EasyCabinetMaker is now in the Gadgets menu.
Due to the User Guide and Help Manual size, I have to post them on my site. You will find download links on the web page.
https://www.jimandi.com/EasyGadgets/Eas ... rHelp.html
As always, I welcome your feedback.
Supports:
- EasyCabinetMaker.zip
- Rename to: EasyCabinetMaker.vgadget
- (513.58 KiB) Downloaded 151 times
Jim
Jim
- jimandi5000
Hello All,
Per request, we added an option for the Base Cabinet Top. You can select Stretchers or Solid Panel for the top. Based on the selection, the proper milling and parts will be added to the drawing and cut list.
Here is version 14.5 and will only work within version 11+ of the VCarve Pro or Aspire.
Supports:
As always, we welcome your feedback.
Supports:
- Rename to: EasyCabinetMaker.vagdget
- (515.4 KiB) Downloaded 138 times
Jim
Jim
- Model of CNC Machine: Shapeoko 3D XXL
is there any place where I can find a setp by step instructions on how to use the cabinet make gadget to make base cabinet from start to finish that show's what is imputed in to the different screens right up to creating the toolpaths.
Thanks Jeff Peters
Thanks Jeff Peters
- Model of CNC Machine: Axiom AR8 PRO V5
Hi Jim's post Feb 6th has a link to the manual,
Happy Easter Jimbo,
I did a test on version 14.5 and attached is what was generated. It looks usable.
I guess if I was to whine about something it would be the fact that both sides should be on some sheet? Or move to a new sheet if they both don't fit on one sheet like they are stacked.
Sheets 2,3 and 4 are not displayed as full size sheets.
Looks like more than one way to do this.
Anyway, thanks for the gadget!
Til Valhalla,
Willy
Til Valhalla,
Willy
- Refridgerator Cabinet.crv
- Quick design, 72 inch
- (1.83 MiB) Downloaded 78 times
- jimandi5000
Hello Willy,dyn0bill wrote: ↑Sat Apr 16, 2022 9:11 pmHappy Easter Jimbo,
Til Valhalla,
Willy
Thanks for the feedback on sheet usage. I'm probably not going to modify the current version of the gadget to support this request. But, I am designing a complete rewrite of the cabinetry suite of gadgets (Easy cabinet, Easy Door, and Easy Drawer maker gadgets) into a single gadget called "Premier Cabinetry" this gadget will be a complete rewrite and consolidation of the previously mentioned gadgets and it will support multiple cabinet styles (face frame, no face frame style cabinets) and I will be adding component to sheet selection as an option. This option will allow the user to set up sheet materials and sheet dimensions. The user and select cabinet components and designate the sheet for the cabinet parts will be drawn and toolpath on.
Again, this will be a complete rewrite so don't expect this to be complete by next week.
Jim
Jim
Jimbo,
Thanks for the info! That sounds like a major undertaking, are you up for it?
Seems like this software is begging for different levels of complexity to be available to the user.
Maybe a Quick cabinet option? The software asks a couple of questions and "BAM" there's the drawing.
For those needing a more complete solution an Advanced cabinet option.
Just sayin'
Anyway, great tool.
Til Valhalla,
Willy
Just sayin'
Anyway, great tool.
Til Valhalla,
Willy
- jimandi5000
Willy,dyn0bill wrote: ↑Mon Apr 18, 2022 8:35 pmJimbo,
Just sayin'
Anyway, great tool.
Til Valhalla,
Willy
I think you are going to really like what I have planed.
You are correct, I believe it takes too much input to get a cabinet out of the current tools. I am rebuilding the user interface and simplifying the the journey from start to output will really help gadget and the user experience.
Jim
Jim
