Easy Cabinet Maker
jimandi5000
Re: Easy Cabinet Maker
Post by jimandi5000 »
Alex-J wrote:
Sat Apr 20, 2024 10:45 pm
I really appreciate all the effort you put into your gadget development! I've only made 10 projects or so, but working towards re-doing my entire kitchen cabinetry thanks to you.
I've been adapting the output of this gadget to make a new bathroom vanity: it's just an extra wide base cabinet with two vertical panels to create 3 sections -- the side sections each having drawers and a set of shelves.
It would be really handy if a "Vanity" option was baked into this gadget which incorporated additional design features specific to this type of project. Thanks again for your development :D
Hi Alex,
Thanks for your appreciation. I have a list of 15 to 18 things people are asking to be added to the cabinet gadget. I will say that "vanities" are on the list. Currently the Base & Wall cabinet have more than 1,700 variations with all the options it currently has for the user to select from. The gadget needs a complete rewritten so the gadget only load and runs the code based on the selected cabinet style and options. Today, it loads everything at once and is getting to be a bear to debug. My plan it to separate the code an build a plug-in base design for the gadget. Based on my work load and my slow speed it may take me a year or so.
Jim
MustStayBusy
Model of CNC Machine: Avid CNC 5x5 pro
Post by MustStayBusy »
Version 18.5 Base cabinets
I'm seeing what I think are a couple issues with this version and have included my export of the settings
The profile tool path does not carry the tool into the toolpath.
The toe kick option does not create the toe kick on the panel.
Let me know if you are seeing something different.
Base185-202406161125.zip
(3.35 KiB) Downloaded 279 times
jimandi5000
I will get on this.
Jim
bpastor
Post by bpastor »
Is this compatible with Aspire v12? I can't get it to install
adze_cnc
Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
Post by adze_cnc »
How can''t you get it to install? What are the steps you are taking to do so?
MustStayBusy
I posted back in June about bugs that I thought I was seeing and have not seen any update. I've messed with as many settings as I can think of and still cannot get version 18.5 to make a toe kick. I assume its on my end, since no one else has mentioned anything. I've uninstalled and checked and rechecked settings to my 16.9 version and still nothing. Do you have any suggestions?
sharkcutup
Post by sharkcutup »
Jim and I are presently looking into this problem Issue. We will get back to this thread gadget Issue soon!
Sharkcutup
V-Carve Pro 12.013
sharkcutup
MustStayBusy wrote:
Fri Sep 20, 2024 9:49 pm
The Bottom of Cabinet needs to be offset the same or just a little more for the Toe-Kick to Fit in the desired location of the Cabinet. Add a Measurement to the Bottom Offset Height Input for the Desired Size Toe-Kick. See the attached Screenshots below.
Thank You for Your Support in using the Gadgets created by jimandi gadgets!
Sharkcutup
V-Carve Pro 12.013
MustStayBusy
Sharkcutup, thank you!
ira
Model of CNC Machine: hd-510
Post by ira »
I tried using it on my laptop, 16" 4K, Scale 200% and it's to small to read, I need to use Magnifier set to 300% to get it to a comfortable size. Not sure how to adjust for DPI on a gadget, but higher resolution screens are getting more common. Not important but thought you might want to know.
jimandi5000
ira wrote:
Sat Sep 21, 2024 7:25 pm
You should be able to use the wheel mouse to increase the display size of the menus. You may need to resize the window size by grabbing the menu corner with the mouse.
Jim
garrettpen
Model of CNC Machine: Millright Mega V
Post by garrettpen »
Is there any documentation for this other than the help screens? Thanks!
jimandi5000
garrettpen wrote:
Sat Oct 19, 2024 11:17 pm
I have not written a current version. Do you have questions? Maybe I could help.
Jim
iutaro
Model of CNC Machine: Leapion 10x5" Richauto b51
Post by iutaro »
hello guys! pretty new to the whole router scene but I've been a metalworker cnc operator for a while now
I just downloaded your gadget and installed it without problems, I've never done a cabinet in my life so i wanted to start with something easy, just a base cabinet, with a single shelf no drawers nothing fancy.
when I input all the data it generates the drawings but the toolpaths are broken
I have to manually delete the tool and re add it otherwise the dado comes out incomplete, like it just machines half of it. the profiles says no tool selected even though I'm selecting a tool on the interface.
I'm sure its just user error but i find myself scratching my head wondering what I'm doing wrong, i can manually redo all the toolpaths to get around it but i worry its a symptom of a larger mess up
I'm using Vcarve Pro with windows eleven and I'm working on metric if that helps
Thanks in advance
Daniel
sharkcutup
Could you post the .export file here by changing the .Export to .txt?
The Above noted Export file is a copy of your settings when you ran the gadget.
I can then import the file (your settings) into the gadget on my computer and then sort out what your problem issue may be.
Sharkcutup
V-Carve Pro 12.013
