Easy Cabinet Maker
- jimandi5000
Re: Easy Cabinet Maker
Did you Upload Files to the Gadget Website? I tried the link and nothing happens when you reach the download page and click the link there!
Sharkcutup
[/quote]
Let me go check!
Sharkcutup
[/quote]
Let me go check!
Jim
Jim
- jimandi5000
Let me go check!jimandi5000 wrote: ↑Thu Jan 25, 2024 3:17 amDid you Upload Files to the Gadget Website? I tried the link and nothing happens when you reach the download page and click the link there!
Sharkcutup
[/quote]
Found the issue. The copy tool failed do to fold space. I have cleaned some out some space and it is working.
Jim
Jim
- jimandi5000
Hello all,
I hope you find joy and happiness everyday.
I am adding Wall and Base "Corner" cabinets to the Easy Cabinet Maker gadget. If any of you have drawings of corner cabinets (as you build them) and could share the drawing with me, I will do my best to incorporate their designs into the Easy Cabinet Maker gadget capability.
Send the drawings to Jim@JimAndI.com
I truly appreciate all of your help and inputs.
Jim
Jim
- sharkcutup
Found the issue. The copy tool failed do to fold space. I have cleaned some out some space and it is working.jimandi5000 wrote: ↑Thu Jan 25, 2024 3:33 amLet me go check!jimandi5000 wrote: ↑Thu Jan 25, 2024 3:17 amDid you Upload Files to the Gadget Website? I tried the link and nothing happens when you reach the download page and click the link there!
Sharkcutup
[/quote]
Thank You, Jim!
Awesome News about the Corner Wall & Base Cabinets being included. That gadget sure is growing!!!
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- jimandi5000
Hello All,
I hope each of you are having a super day.
I address an issue with the Easy Cabinet Maker gadget.
Item Fixed:
1. Sheet layout error. The sheet was the wrong width when oriented in the vertical layout position.
Under Construction:
1. Adding corner cabinets for the Wall and Base cabinet. Designing the cameras to support a single door or bifold door.
Current Version: 17.3
Supports: 11.0+ version of 2D Cut Pro, VCarve Pro, and Aspire
Installation Instructions:
1. Open https://www.gadgets.jimandi.com/
2. Sort on the PostOrder column to see the most current post
3. Select the Download button for the EasyCabinetMaker.vgadget
4. In your Vectric product, click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it, and click Ok.
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer17.3 in the Gadgets menu.
Your feedback and suggestions are always appreciated.
Be sure to sign up on our gadget website to be notified when Easy Gadgets updates are posted.
Item Fixed:
Under Construction:
Jim
Jim
- Ken Rychlik
- Model of CNC Machine: Buy, fix, and sell them
Jim, on the corner units, the left and right sides are the same as normal base and upper. Just the center pieces and backs are different. There is a left back and a right back instead of just a single back. Some guys prefer a back corner clipped off, as many inside corners of a house are not square. Not going all the way to the corner helps with installations. It was about a 6 inch section across at a 45 degree cut out of the back. There were some on that xl spreadsheet version I sent you several years ago. You have taken it to a whole different level than I had done and I'm glad to see it. Take care
Custom CNC Work
Local Machine Repairs and Programming
- jimandi5000
Hello All,
I hope each of you are hip deep in happiness.
I address an new issue with the Easy Cabinet Maker gadget.
Item Fixed:
1. Showed an Error message when there was no error.
Under Construction:
1. The dev version can draw parts for the Wall corner cabinet.
Current Version: 17.4
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer17.4 in the Gadgets menu.
Item Fixed:
Under Construction:
Jim
Jim
- jimandi5000
Hello All,
I bet you can guess what I've been doing all day.
I have addressed another issue in Easy Cabinet Maker gadget.
Item Fixed:
1. Wall Cabinet - Side panel mirroring issue. Found the side panels in the wall cabinet were not mirroring properly and were creating two left or two rights. This issue has been fixed and is supporting the new joinery (rabbit or dado) capability that was recently added.
Under Construction:
You can see some of the new functionality in this version. You want, you can have a peek at the wall corner cabinet current capabilities. At the bottom of the main menu is a dropdown list of what to be drawn (work in progress).
Current Version: 17.5
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer17.5 in the Gadgets menu.
If you find an issue with any of the easy gadgets, please let me know. I will do what I can to fix it within hours not days and weeks.
Without your feedback and suggestions the stone is sure hard to roll uphill. So keep them coming
Item Fixed:
Under Construction:
Jim
Jim
- jimandi5000
Sorry!
Found a un-localized variable and it was popping an error.
Try try 17.5.1
Try try 17.5.1
Jim
Jim
- jimandi5000
Sorry Again!jimandi5000 wrote: ↑Sat Jan 27, 2024 10:26 pmSorry!
Try try 17.5.1
I cannot upload 17.5.1 due the database will not support the format.
The Version 17.5 that is on the site doesn't have any issues. Please download it.
Jim
Jim
- jimandi5000
Hello all,
I hope you are doing great today.
I have been asked for an enhancement to the Easy Cabinet Maker gadget and I assume to my other gadgets as well. The request is to support multiple languages. For smaller gadgets this is a manageable effort for the larger gadgets this could be a significant effort.
I am currently working on a French version of the Easy Cabinet Maker and would like to know is there a need for multi-language gadgets in the user base?
If so, let me know the language you need for me to start supporting and which of the Easy gadgets you are utilizing.
With this information I can prioritize and focus my efforts.
Jim
Jim
- jimandi5000
Hello All,
Item Fixed:
1. API and current language - found a API call that returns values in the current user language. I have implemented a drop-down list the user can select their current language in this will address the problem with image stacking.
Supporting: English, French, French, Spanish, German, Italian, Polish and Danish
Under Construction:
1. This version can draw the Face-frame Wall corner cabinet version. (Face-frame and shelving to come)
Current Version: 18.2
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer18.2 in the Gadgets menu.
Be sure to sign up on our gadget website to be notified by email when Easy Gadgets updates are posted.
Item Fixed:
Under Construction:
Jim
Jim
- jimandi5000
- jimandi5000
Hello All,
Found and Fixed another issue in Easy Cabinet Maker gadget.
Item Fixed:
1. Base Cabinet - fix the center panel length issue.
Note: The new version 12.0 has updated the html compiler engine (displayer of the html dialog menus) and you will need to resize the menus one time after loading the gadget. Just select the edge of the menu with your mouse and adjust as needed.
Current Version: 18.5
Supports: 11.0, 11.5, 12.0 versions of 2D Cut Pro, VCarve Pro, and Aspire
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer18.5 in the Gadgets menu.
Item Fixed:
Jim
Jim
- Model of CNC Machine: Shapeoko 5 4x4
I really appreciate all the effort you put into your gadget development! I've only made 10 projects or so, but working towards re-doing my entire kitchen cabinetry thanks to you.
I've been adapting the output of this gadget to make a new bathroom vanity: it's just an extra wide base cabinet with two vertical panels to create 3 sections -- the side sections each having drawers and a set of shelves.
It would be really handy if a "Vanity" option was baked into this gadget which incorporated additional design features specific to this type of project. Thanks again for your development
