Easy Cabinet Maker
sharkcutup
Re: Easy Cabinet Maker
Post by sharkcutup »
Merry Christmas and Happy New Year Jim!!!
Sharkcutup
V-Carve Pro 12.013
donavanshomes
Model of CNC Machine: yeti smart bench
Post by donavanshomes »
let me know if you need anything else
thanks again
jimandi5000 wrote:
Sun Dec 31, 2023 5:24 pm
donavanshomes wrote:
Sun Dec 31, 2023 5:19 pm
this is about dados in Easy Cabinet Maker not sure why i would post this too Dovetail thread???
jimandi5000 wrote:
Sun Dec 31, 2023 3:52 pm
This is posted on the wrong thread. Post this on the Dovetail thread and add images or the drawing.
Export the cabinet settings and post the setting and the drawing files.
I will review the issue.
New.crv
(829.5 KiB) Downloaded 130 times
first-202312311026.Export.txt
(19.33 KiB) Downloaded 130 times
jimandi5000
Post by jimandi5000 »
Working on it...
Jim
jimandi5000
Hello All,
I hope each of you are having a great day.
I address an issue with the Easy Cabinet Maker gadget.
Item Fixed:
1. Wall cabinet side panel, the back panel dado was the wrong width
Current Version: 16.9
Supports: 11.0+ version of 2D Cut Pro, VCarve Pro, and Aspire
Installation Instructions:
1. Open https://www.gadgets.jimandi.com/
2. Sort on the PostOrder column to see the most current post
3. Select the Download button for the EasyCabinetMaker.vgadget
4. In your Vectric product, click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it, and click Ok.
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer16.9 in the Gadgets menu.
Your feedback and suggestions are always appreciated.
Be sure to sign up on our gadget website to be notified when Easy Gadgets updates are posted.
Jim
donavanshomes
First off thanks for all of the work you do
I installed Ver 16.9 and getting a error message cannot open EasycabinetLibrayver16.9.xlua no such file or directory when i look at the file directory the files have name ver116.9 on them instead ver16.9. Can i just rename them?
Donavan
jimandi5000 wrote:
Sun Dec 31, 2023 6:38 pm
Hello All,
Item Fixed:
jimandi5000
I will have a look.
Jim
jimandi5000
Sun Dec 31, 2023 7:51 pm
Donavan
Hello All,
Item Fixed:
File name issue was addressed. if you have downloaded the gadget you will need to re-download it.
Jim
donavanshomes
working great now thanks
jimandi5000 wrote:
Sun Dec 31, 2023 9:03 pm
Donavan
Hello All,
Item Fixed:
jimandi5000
Yea!!!
Yea!!!
Nailed IT.png (23.28 KiB) Viewed 11029 times
Jim
donavanshomes
Is the there a way to do dados for the tops and bottoms on upper cabinets 3/4" to a 1" up or down in from the end instead of rabbits on end of the side panels
Donavan
jimandi5000
Sun Dec 31, 2023 9:23 pm
Donavan
Hello Donavan,
Yes, I write custom gadgets.
Send me an email with a drawing of what you are needing at Jim@Jimandi.com
Jim
jimandi5000
Hello All,
I hope each of you are having a super day.
I added a new option to the Easy Cabinet Maker gadget.
Item Added:
1. Wall cabinet Top and Bottom panel, can now be set to be milled as a Dado or a Rabbet joint. Before you could only have Rabbet joints.
Current Version: 17.0
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer17.0 in the Gadgets menu.
The site emails look like this:
Jim
jimandi5000
Hello All,
I hope each of you are staying warm... Winter has found Houston Texas.
I found and fixed and small issue in the Easy Cabinet maker gadget. Here is the updated version.
Item Fixed:
1. Base cabinet logic - When using a half-blind dado and "No center panel" the code did not notch the corners for the dados of the top stretcher.
Current Version: 17.1
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer17.1 in the Gadgets menu.
Jim
jimandi5000
Hello All,
I hope each of you are staying dry... The rain is falling here in Houston Texas.
A small issue was found in the Easy Cabinet maker gadget. Here is the updated version.
Item Fixed:
1. Base cabinet logic - A user set me a message and discovered a variable was not being properly set within a logic tree. The issue has been resolved and a new version has been posted.
Current Version: 17.2
You should be presented a pop message up saying the gadget was installed and you should see the EasyCabinetMakerVer17.2 in the Gadgets menu.
Jim
sharkcutup
jimandi5000 wrote:
Wed Jan 24, 2024 11:52 pm
Hello All,
Item Fixed:
Did you Upload Files to the Gadget Website? I tried the link and nothing happens when you reach the download page and click the link there!
Sharkcutup
V-Carve Pro 12.013
