Easy Cabinet Maker
- jimandi5000
Re: Easy Cabinet Maker
I am thinking of adding corner cabinets to the gadget.
Any thoughts or suggestions?
Jim
Jim
- sharkcutup
That is AWESOME!!!jimandi5000 wrote: ↑Sun Aug 27, 2023 7:36 pmI am thinking of adding corner cabinets to the gadget.
Who ya going to get to Beta Test Them?
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- jimandi5000
Hello All,
Supper Wow! Three updates in the same day.
Items Fixed:
1. The stretcher length issue with center panel.
Current Version: 16.6
Supports: 11.0+ version of 2D Cut Pro, VCarve Pro, and Aspire
Installation Instructions:
1. Open https://www.gadgets.jimandi.com/
2. Sort on the PostOrder column to see the most current post
3. Select the Download button for the EasyCabinetMakerRel16.6.vgadget
4. In your Vectric product, click on Gadgets -> Install Gadget and navigate to where you downloaded the file to, select it, and click Ok.
You should be presented a pop message up: You should find in the Gadgets dropdown menu a folder named EasyCabinetMakerRel16.6 with the EasyCabinetMakerVer16.6 gadget.
Your feedback and suggestions are always appreciated.
Be sure to sign up on our gadget website to be notified when new gadgets or patches are posted.
Items Fixed:
You do not have the required permissions to view the files attached to this post.
Jim
Jim
- jimandi5000
Hello All,
Sorry for all the postings.
Items Fixed:
1. The error message for wall cabinet with no center panel.
Current Version: 16.7
3. Select the Download button for the EasyCabinetMakerRel16.7.vgadget
You should be presented a pop message up: You should find in the Gadgets dropdown menu a folder named EasyCabinetMakerRel16.7 with the EasyCabinetMakerVer16.7 gadget.
Items Fixed:
Jim
Jim
- Model of CNC Machine: Avid CNC 5x5 pro
I would love to look at corner cabinets, added to the widget.
Version 16.7 I'm getting a couple of messages.
I'm also getting errors, no assy drilling layer found with name = assemblyholestop stretcher-base
alert: the rear side clearance value will impact the cabinet inside wall.
- sharkcutup
No Assy Drilling Layer found with name = AssemblyHolesTop Stretcher-Base
Error Item 1
This is due to fixing the Base Stretcher Issue with Center Panel Added to Base (Assy Holes and Dadoes were not being applied to Stretchers - Now Fixed) but now evidently he gadget is looking for the same Layer when no Center Panel is required/requested.
Error Item 2
alert: the rear side clearance value will impact the cabinet inside wall. --- Have not seen this ERROR yet!
Corner Cabinets are in the Works!!!
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- sharkcutup
Finally was able to replicate this Error to view it.Error Item 2
It may be just a warning and does not affect your cabinet outcome. We will look into what may be causing this Alert and notify of status.
Sharkcutup
V-Carve Pro 12.013
V-Carve Pro 12.013
- tdwilli1
- Model of CNC Machine: Onefinity Elite
So I just installed this and if I don't choose a toe kick I get an error message.
- Model of CNC Machine: AXYZ 4008 (VCarve Pro v9.519)
Jim and Sharky:
Looks like lines 6803-6807 of EasyCabinetBaseVer16.7.xlua need a "local" prepended to match the other pt values:
And while you're changing things in that file you could change line 42 to:
So that str1 doesn't get intialized to nil.
EDIT: oops! Editor opened wrong file. That line 42 is in: EasyCabinetLibraryVer16.7.xlua
Code: Select all
if BaseCal.BackPanelDados then
ptC = Polar2D(ptB, 90.0, Milling.PocketToolRadius + BaseDim.ThicknessBack + (BaseDim.StretcherWidth - Milling.DadoBackHeight))
else
ptC = Polar2D(ptB, 90.0, Milling.PocketToolRadius + BaseDim.ThicknessBack + BaseDim.StretcherWidth)
end
Code: Select all
local ptC = Polar2D(ptB, 90.0, Milling.PocketToolRadius + BaseDim.ThicknessBack + (BaseDim.StretcherWidth - Milling.DadoBackHeight))
else
local ptC = Polar2D(ptB, 90.0, Milling.PocketToolRadius + BaseDim.ThicknessBack + BaseDim.StretcherWidth)
end
Code: Select all
local outStr, str1 = "", ""
- tdwilli1
Are the slide holes made for Blum undermount?
- jimandi5000
The gadget supports array of configuration for drawer slides holes and offsets. Please post a image of the Blum undermount in question so that I don't mislead you.
Jim
Jim
- jimandi5000
Let me have a look.adze_cnc wrote: ↑Wed Sep 27, 2023 11:55 pmJim and Sharky:
Code: Select all
if BaseCal.BackPanelDados then ptC = Polar2D(ptB, 90.0, Milling.PocketToolRadius + BaseDim.ThicknessBack + (BaseDim.StretcherWidth - Milling.DadoBackHeight)) else ptC = Polar2D(ptB, 90.0, Milling.PocketToolRadius + BaseDim.ThicknessBack + BaseDim.StretcherWidth) end
And while you're changing things in that file you could change line 42 to:Code: Select all
if BaseCal.BackPanelDados then local ptC = Polar2D(ptB, 90.0, Milling.PocketToolRadius + BaseDim.ThicknessBack + (BaseDim.StretcherWidth - Milling.DadoBackHeight)) else local ptC = Polar2D(ptB, 90.0, Milling.PocketToolRadius + BaseDim.ThicknessBack + BaseDim.StretcherWidth) end
So that str1 doesn't get intialized to nil.Code: Select all
Jim
Jim
- jimandi5000
Hello All,
Thanks to adze_cnc for his help on finding the code issues.
Items Fixed:
1. No loculation of a variables
Current Version: 16.8
3. Select the Download button for the EasyCabinetMakerRel16.8.vgadget
You should be presented a pop message up: You should find in the Gadgets dropdown menu a folder named EasyCabinetMakerRel16.8 with the EasyCabinetMakerVer16.8 gadget.
Items Fixed:
Jim
Jim
- Tex_Lawrence
- Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 12.013
For the life of me, I can't figure out what you fixed. Did you have to use a medical surgical procedure to fix it? Spellcheck strikes again?
Tex — Crooked Wood Products
- jimandi5000
LOL!!!Tex_Lawrence wrote: ↑Sun Oct 01, 2023 11:51 amFor the life of me, I can't figure out what you fixed. Did you have to use a medical surgical procedure to fix it? Spellcheck strikes again?
Should have been "Error thrown for variables that had not been substantiated with the function called local"
You got to just have to have a good laugh sometime.
LOL!
Jim
Jim
