Easy Cabinet Maker
- Model of CNC Machine: EZ Route 4x8/WinCNC
Re: Easy Cabinet Maker
Jimbo,
Faster horses, younger women and better drugs!
No problem with the double milling.
Willy
Willy
- Model of CNC Machine: ShopSabre Pro404
Hey Jim!
First off Kudos to you! This gadget is great!
I did find a small bug with the face frames though. Not that I am milling face frames but I do like the reference. It draws them at the full height of the cabinet which is fine for the wall cabs but not the base cabinets There is also a typo "Shelf End Clarence"
- jimandi5000
Howdy everybody,
I was able to fix the cabinet gadget issues with the Wall Cabinet back panel. So here's the new version EasyCabinetMakerVer11.6 gadget with some new features as well.
Errors Fixed:
1. Back panel length calculation
2. Top and bottom rabbit not being drawn and toolpath applied if center panel was not added
3. Spelling errors
New Features:
1. Export all (205+) user settings of current cabinet configuration
2. Import a selected previous export file.
Supports: Vectric Aspire and V Carve Pro versions 10+
Next Steps:
1. Update Help Files
2. Add some more error trapping
Errors Fixed:
3. Spelling errors
New Features:
Next Steps:
- EasyCabinetMakerVer11.6.zip
- Rename to: EasyCabinetMakerVer11.6.vgadget
- (54.28 KiB) Downloaded 81 times
Jim
Jim
- jimandi5000
Howdy everybody,
I hope your day is full of joy happiness.
I fixed the Easy Cabinet Gadget base face frame issues. So here's the new version EasyCabinetMakerVer11.7 gadget with some new features as well.
Error Fixed:
1. Base Face Frame length calculation
New Features:
1. Error trapping on Import and Exporting files
2. New Sheet selection is disabled for Vectric version 11 and above
3. Updated Help Files on all changes
4. Added folders inside the vgadget load file. This will show up in the Gadget pull down menu.
Supports:
Next Steps:
1. Add an option to place Drill holes for screws in sides panels for cabinet assembly
2. I may make a video on how to use the gadget? (let me know if you want one)
Any issues or request?
Error Fixed:
New Features:
Supports:
Next Steps:
- EasyCabinetMaker.zip
- Rename to: EasyCabinetMaker.vgadget
- (54.78 KiB) Downloaded 61 times
Jim
Jim
Howdy Jimbo,
Happy Thanksgiving!
I will give the new version a try, I am sure you have made some positive changes.
I think a video would be great! Save some time learning the gadget.
'til Valhalla
Willy
Happy Thanksgiving!
'til Valhalla
Willy
- jimandi5000
Thanks Willy. I will finish the the pilot hole up grade and start working with the script for a how to video.
Jim
Jim
Jimbo,
If I can be of any help with the video, or anything, let me know.
Willy
Willy
- jimandi5000
will do on the help. And may I say that is a nice CNC Mill you got there...
Jim
Jim
- jimandi5000
Howdy everybody,
Great Joy and happiness to you and your families on this Thanksgiving day.
I've been going through the Easy Cabinet Gadget code in great detail. I have a new version of the EasyCabinetMakerVer11.8 gadget with a number of fixes and some new features.
Error Fixed:
1. Base - Toe kick width was incorrect
2. Base - Top stretch width was incorrect
3. Part identification callout and Bill of materials had some parts width and length inverted values (Toe kick, Stretchers and Bottom)
New Features:
1. Added (optional) Assembly Pilot Holes (Base and or Wall cabinets)
2. Modified milling dialogue for options on Assembly pilot holes
3. Updated main dialogue for assembly pilot hole bit selection for the toolpath
Supports:
Next Steps:
1. Update help files to reflect the new enhancements
2. Make a YouTube video on how to use this gadget
Error Fixed:
New Features:
Supports:
Next Steps:
- (57.34 KiB) Downloaded 54 times
Jim
Jim
Jimbo,
Many thanks for your effort!
How do I remove the older rev's of Easy Cabinet Maker?
My gadget list is getting crowded.
Willy
Willy
For Windows 10 (and presumably recent previous versions of Windows) you can find them at:
Within that will be your product (Aspire or VCarve) and within that the old versions of Easy Cabinet Maker that you no longer need.
Code: Select all
C:\Users\Public\Documents\Vectric Files\Gadgets
- jimandi5000
Howdy everybody,
I hope you are having a great day.
I received a message on my latest update that some of the Assembly Pilot Holes were doubled up (sitting directly on top of each other).
It was a quick fix and wish I had caught it before I posted.
Please find the attached zip file containing EasyCabinetMaker Version 11.9
Error Fixed:
1. Double stacked Assembly Pilot Holes
Supports:
Next Steps:
2. Make a "How To" video on this gadget
Error Fixed:
Supports:
Next Steps:
- (57.21 KiB) Downloaded 70 times
Jim
Jim
Thanks Jimbo,
I will take a look at it as soon as I get my server back up.
Attached is a variation of the boxes I suggested for a gadget consideration. I realize it is really just boxes but could be built like a cabinet.
We sure need a cabinet door gadget using VCarve and staying within a certain spec.
Carpe diem
Willy
Carpe diem
Willy
- jimandi5000
Willy,
"We sure need a cabinet door gadget using VCarve and staying within a certain spec."
Let me see some spec's...
Have you seen this post?
viewtopic.php?f=51&t=37869
Jim
Jim
- jimandi5000
dyn0bill wrote: ↑Fri Nov 26, 2021 10:20 pmThanks Jimbo,
Carpe diem
Willy
Hi Willy,
Do you have spec's on how these boxes are assembled?
- Corner joint type (45, But joint, Dove tail, Box Joint, etc..)
- Back is flush mount or rabbit or dado (reset)
- Face frame, etc
Jim
Jim
