Easy Cabinet Maker
Re: Easy Cabinet Maker
Post by adze_cnc »
I expect the "it doesn't show up" above might be related to this
sharkcutup
Post by sharkcutup »
adze_cnc wrote:
Mon Oct 17, 2022 9:42 pm
Gosh are we having fun yet?
Sharkcutup
V-Carve Help is Available!!!
Private Message Me!
V-Carve Pro 11.504
Post by adze_cnc »
Hey Jim and Sharkcutup. Some minor errors in EasyCabinetMakerV14.9. Most of the "errors" are initial assignments that are short a parameter or two. This just means the variable will be initialised to "nil" instead of a number or string value (as needed). The only major error is the multiple calls to the function CreateLayerDrillingToolpath(...)
Steven
EasyCabinetBaseVer14.9.xlua
line 38:
Code: Select all
local HoleSpace, HoleCount = 0
should be
Code: Select all
local HoleSpace, HoleCount = 0, 0
line 246:
Code: Select all
BaseDim.DrawerHeight, AQ = 0.0
should be (?)
Code: Select all
BaseDim.DrawerHeight, AQ = 0.0, 0.0
EasyCabinetDialogVer14.9.xlua
line 585:
Code: Select all
AddNewGroupWriter(Hardware.Name)
The function definition in file EasyCabinetHardwareVer14.9.xlua (line 300) does not accept a parameter.
EasyCabinetToolV14.9.xlua
line 759:
Code: Select all
local sThick, sWidth, sLength = ""
should be
Code: Select all
local sThick, sWidth, sLength = "", "", ""
line 1207:
Code: Select all
local Red, Green, Blue = 0
should be (note: line 1203 is right)
Code: Select all
local Red, Green, Blue = 0, 0, 0
EasyCabinetMakerVer14.9.xlua
lines 181, 194, 298, 312, 317, 320, 372, 373, 394, and 398 are all similar so I will only show line 181 below:
Code: Select all
CreateLayerDrillingToolpath(Milling.LNSideShelfPinDrill .. "-Wall", Milling.Sheet .. "Wall Side Panel Pin Drilling", 0.0,  Milling.ShelfPinLen, Milling.ShelfPinLen * 0.25, Milling.ShelfPinLen * 0.35)
In each of the lines noted above the call is providing 6 parameters but the function definition is only set to accept 5 parameters:
Code: Select all
function CreateLayerDrillingToolpath(layer_name, name, start_depth, cut_depth, retract_gap)
jimandi5000
Post by jimandi5000 »
adze_cnc wrote:
Tue Jan 10, 2023 12:18 am
Steven
line 38:
Code: Select all
should be
Code: Select all
line 246:
Code: Select all
should be (?)
Code: Select all
line 585:
Code: Select all
line 759:
Code: Select all
should be
Code: Select all
line 1207:
Code: Select all
Code: Select all
Code: Select all
Code: Select all
Thank for looking at this... I am 98% compete with Version 15+ but I will make sure I cover these... I may need to ping you on some of them.
Jim
cusoak
Post by cusoak »
I have a set of base cabinets I want to make using the Easy cabinet maker.
If could send or post here the sizes of the 3 cabinets could some one use the easy cabinet maker to show how they would do all of the steps are done to get it to the point of nesting and cut
Thanks Jeff Peters
jimandi5000
cusoak wrote:
Thu Jan 12, 2023 3:11 pm
Thanks Jeff Peters
Hi Jeff,
If you will post the details of the cabinet's (height, length, depth, materials, Y/N face-frame, drawers, shelfs, etc.) you want to build. I will make a video for you that shows how I would use the EasyCabinetMaker gadget.
Jim
Jim
sharkcutup
+1 Agreed
I can do that too Jim that is if you are too busy with other things. I am here if needed.
Sharkcutup
Private Message Me!
V-Carve Pro 11.504
RickW3DS
Model of CNC Machine: LongMill 30x30
Post by RickW3DS »
Would be good to have a video for this one, lots of things we can mess up when just tinkering with settings.
sharkcutup
by RickW3DS -- Would be good to have a video for this one, lots of things we can mess up when just tinkering with settings.
That is why there is a system reset on the About Menu Interface for resetting the gadget back to its default settings.
But yeah a video would be helpful also!!!
Sharkcutup
Private Message Me!
V-Carve Pro 11.504
RickW3DS
Post by RickW3DS »
Sometimes we just click and go left...
Yep, video would helpusgoobers
MustStayBusy
Model of CNC Machine: Avid CNC 5x5 pro
Post by MustStayBusy »
Yes, would love a video on how to use
aa1pi
Model of CNC Machine: KRMx01
Post by aa1pi »
Can I report an error I found in "The cabinet cut-list" Item ID 100 left side panel...……..width 10 3/4" length 10 3/4
Item ID 110 Right side Panel width 10 3/4 length 18-5/16
The length of item 100 should read 18-5/16
Everything is ok in the drawing.
Great program so much work even the documentation.
sharkcutup
aa1pi wrote:
Thu Feb 02, 2023 1:10 am
What Version of the Cabinet Maker created that Cutlist File? Not that it really matters it needs to be rectified/resolved but would be interested in knowing.
Sharkcutup
Private Message Me!
V-Carve Pro 11.504
aa1pi
Post by aa1pi »
The version is 14.9
Post by adze_cnc »
sharkcutup: file EasyCabinetWallVer14.9.xlua
approx. line 442
Code: Select all
CutListfileWriterItem(BOM.PID, "Left Side Panel","Wall", "1",
	WallDim.MaterialThickness, BOM.WallCabinetMateralType, BOM.WallCabinetFinish,
	WallDim.SidePanelWidth, WallDim.SidePanelWidth)
approx. line 583
Code: Select all
CutListfileWriterItem(BOM.PID, "Right Side Panel","Wall", "1",
	WallDim.SidePanelWidth, WallDim.SidePanelLength)
In 442 there is duplicate SidePanelWidth
