Hello All,
I hope you are have some fun today!
I have added the grouping function to the Notes and Part Numbers to the Easy Draw Maker Version 3.5. This should make it easier to move the test.
Supports: Vectric 10+
Drawer Maker
- jimandi5000
Re: Drawer Maker
Jim
Jim
- jimandi5000
Re: Drawer Maker
I got a HTML Error on the Attachment.jimandi5000 wrote: ↑Wed Sep 22, 2021 4:04 pmHello All,
- EasyDrawerToolsVer03.5.zip
- Rename to: EasyDrawerToolsVer03.5.vgadget
- (32.67 KiB) Downloaded 336 times
Jim
Jim
- Model of CNC Machine: ShopSabre Pro404
Re: Drawer Maker
I am trying to use the Drawer Maker Gadget but run into an issue that it is creating the objects off of my sheet. I am trying to create a single drawer
- jimandi5000
Re: Drawer Maker
Hi Mr Ramsey1969,mrramsey1969 wrote: ↑Sat Oct 16, 2021 5:36 pmI am trying to use the Drawer Maker Gadget but run into an issue that it is creating the objects off of my sheet. I am trying to create a single drawer
As you may know the gadget was designed to support multiple material thicknesses and draw the drawer parts on the material thickness sheet. The recent changes in Vectric version 11 has changed their Sheet functionality and has not provided a SDK update to control the new function. Therefore, I found it necessary to disable the sheet creation functions and draw each part based on its material thickness in a location where it is separate from the other parts.
For instance, if you were to draw a drawer with a 1" thick front, 3/4" of an inch sides, a 1/2" back, and 1/4" bottom. The gadget would produce for sheets one sheet for each material thickness. As necessary because the milling is different based on material thicknesses.
I hope this helps and please let me know if you have other questions.
Jim
Jim
Re: Drawer Maker
Hi Jim,jimandi5000 wrote: ↑Sun Oct 17, 2021 3:50 pmHi Mr Ramsey1969,mrramsey1969 wrote: ↑Sat Oct 16, 2021 5:36 pmI am trying to use the Drawer Maker Gadget but run into an issue that it is creating the objects off of my sheet. I am trying to create a single drawer
Thanks for the reply! That makes sense. I was finally able to generate the parts correctly. Hopefully Vectric will get you the update to the SDK soon!
Re: Drawer Maker
A new version of the SDK has been released: https://gadgets.vectric.com/v11/gadget-sdkjimandi5000 wrote: ↑Sun Oct 17, 2021 3:50 pmThe recent changes in Vectric version 11 has changed their Sheet functionality and has not provided a SDK update to control the new function. Therefore, I found it necessary to disable the sheet creation functions and draw each part based on its material thickness in a location where it is separate from the other parts.
Greg K
- jimandi5000
Re: Drawer Maker
Thanks Greg!gregk wrote: ↑Tue Oct 19, 2021 1:54 pmA new version of the SDK has been released: https://gadgets.vectric.com/v11/gadget-sdkjimandi5000 wrote: ↑Sun Oct 17, 2021 3:50 pmThe recent changes in Vectric version 11 has changed their Sheet functionality and has not provided a SDK update to control the new function. Therefore, I found it necessary to disable the sheet creation functions and draw each part based on its material thickness in a location where it is separate from the other parts.
Greg K
I now have something to work on.
Jim
Jim
- jimandi5000
Re: Drawer Maker
Hi there all,
Here is the Easy Drawer Maker 4.0 and it will only work on Version 11+ of VCarve or Aspire.
- EasyDrawerMakerVer4.0.zip
- Rename to: EasyDrawerMakerVer4.0.vgadget
- (33.63 KiB) Downloaded 162 times
- C1-202201051314.zip
- BOM (dat and csv) files
- (750 Bytes) Downloaded 110 times
Jim
Jim
