Easy MDF Cabinet Door Maker
Re: Easy MDF Cabinet Door Maker
Post by adze_cnc »
Minor "error" that doesn't affect functionality. In the main ".lua" file:
Code: Select all
  if Door.Count < 1 then
    Pdialog:UpdateLabelField("Door.Alert", "Error: Door Count Requird")
  elseif Door.Count < 1 then
    Pdialog:UpdateLabelField("Door.Alert", "Error: No Door Count Provided")
First elseif of this chain is redundant.
Post by adze_cnc »
Question: shouldn't the "Door Layout Spacing" value be a gap between doors?
Right now it is the distance between the left edges of multiple doors. This means that it should be larger than the width of the door. But, that means that every time the door width changes the "Door Layout Spacing" should be changed.
But, if it is a gap between doors then largely it could be set once and then be forgotten about.
Post by adze_cnc »
If you choose a v-bits for any of the options that allow v-bits...
...then no matter what angle bit you choose the toolpaths created with those bits will be created with a constant angle of 90 degrees.
All angled area should be cut with 15 deg included angle not 90 deg.
For example this outside edge toolpath is set 1/8" deep. With a 90 degree bit its width would be 0.250 inches and the image shows (within the skill of my select a dimension by eye) shows that to be the case. If this was using a 15 degree bit as specified this result would be much smaller.
The reason this happens is (as I've posted elsewhere in this forum) that the SDK PDF is in error when it says something like this:
Code: Select all
tool.VBitAngle = MillTool8.VBitAngle  -- 90.0 -- used for vbit only
The code should be:
Code: Select all
tool.VBit_Angle = MillTool8.VBitAngle  -- 90.0 -- used for vbit only
In a way the comment is correct that if using the 1st line you will get a 90 degree angle.
There are only a small number of places this needs to be altered:
Post by adze_cnc »
EDIT: OK. I expect what's happening is that because I am using the Trial version all file writing whether it be gadgets, post-processor output, etc. is being disabled.
I tried the code below in VCarve v9.519 and all ran fine. Oops. Sorry for the confusion.
Jim,
Further to the "open invalid mode" error above. This code when run from ZeroBrane works fine (all 3 files created). When pasted into VCarve 11 (trial) gives the error as with the link.
Code: Select all
-- VECTRIC LUA SCRIPT
file = io.open("c:\\temp\\test.dat", "w")
file:write("================================================================ \n")
file:write("=====================  Tray Cut-list  ======================== \n")
file:close()
file = io.open("c:\\temp\\test.csv", "w")
file:write("ID,Name,Count,Thick,Material,Width,Length\n")
file:close()
file = io.open("c:\\temp\\test.html", "w")
file:write([[<html><head><title>Easy Tray Maker Bill of Material</title></head>
<body>Test HTML file</body</html>]])
file:close()-- closes the the Tray on the open file
jimandi5000
Post by jimandi5000 »
adze_cnc wrote:
Sun Aug 07, 2022 10:42 pm
Jim,
Code: Select all
file:close()
file:close()
Hi ADZE CNC,
Thanks for the feedback. I will set aside some time to updating the code.
Again, truly thank you. Without feedback it is very hard to produce a quality solution.
Jim
sharkcutup
Post by sharkcutup »
Has anyone tried the Easy MDF Door Maker Gadget using the OVAL Door Style???
Does it work or does it show a pop-error message?
Just Curious and wanting to know if that I was the only one getting the pop-up message when trying to use the Oval Door Style during my BETA testing of this Gadget.
Sharkcutup
V-Carve Pro 11.554
sharkcutup
posted by adze_cnc While we're at it on the "Default Settings" pop-up the following changes could be made:
"Inner Frame Line" instead of "Inter..."
Sometimes "fluting" is used and sometimes "flute". Might be best to standardize on one
"Inside Edge Milling". It's unclear as to what this actually does. What inside edge?
Could be Either 'inter' or 'inner' they both refer to the inside area of the door. Could be Standardized as one or the other. I have changed my copy of the gadget to 'inner'
Have not looked at 'fluting' versus 'flute'. Will take a quick gander at this one today.
"Inside Edge Milling" This is the door side edge of the pocket. Reference attached drawings
Sharkcutup
V-Carve Pro 11.554
sharkcutup
jonathanmahnken wrote:
Fri Aug 05, 2022 1:55 am
I have used it to make some shaker style fronts. Im new to making mdf doors, and I do plan on other styles in the future. It would be nice to be able to enter an entire list of doors and have that lay out onto a sheet with specified spacing. Maybe it does and I just dont know how to use it...
Something Like This???
Sharkcutup
V-Carve Pro 11.554
Post by adze_cnc »
sharkcutup wrote:
Sun Aug 21, 2022 1:01 pm
Inter-frame: yes. Inner frame: parallelism with “outer frame”. Inter frame is to place the frame in a grave or tomb.
:D
sharkcutup
adze_cnc wrote:
Sun Aug 21, 2022 4:42 pm
:D
Thank You Steven!!!
Could you do me a favor? Test the Oval Style Door and let me know if it works or do you get a pop-up error?
Sharkcutup
V-Carve Pro 11.554
Post by adze_cnc »
From a fresh install of the gadget I added some tools (1/4” end mills, 1/4” ball noses, and 90 deg v-bits). I then created a door using default values listed. Success. I then created 4 doors using defaults. Success.
I presume that you are getting an error. Do you have a screenshot of that error?
sharkcutup
Great!!!
I was getting an error but I fixed my copy of the Gadget and now that Style works fine.
It was getting a pop-up saying that it did not recognize a variable 'pty'
Thank you for your Time in checking for me!!! :)
Sharkcutup
V-Carve Pro 11.554
sharkcutup
EDIT ----
Okay sorry it was when I tried to create Oval Style Door with Crossing Flute Lines. I got a unknown variable 'pty' error pop-up. Fixed my resident copy of the gadget. Then another problem arose and managed to fix that too. Now to continue with more BETA TESTNG.
Sharkcutup
V-Carve Pro 11.554
sundown
Model of CNC Machine: AvidCNC
Post by sundown »
Hi Jim -
I'm receiving a "No layer found with name = Door Scribe Lines" and "Door Flutes" with the attached settings. Though as far as I can tell, I'm not missing a toolpath or any design element.
Have I misinterpreted a setting/tool usage, perhaps? Thanks for the gadget and any help you can provide!
jimandi5000
sundown wrote:
Fri Oct 14, 2022 9:43 pm
Hi Jim -
Have I misinterpreted a setting/tool usage, perhaps? Thanks for the gadget and any help you can provide!errormsg.jpg
Hi Sundown,
What Vectric Product and Version are you running with the gadget?
Jim
Jim
