Easy Cabinet Maker
jimandi5000
Re: Easy Cabinet Maker
Post by jimandi5000 »
Hello boys and girls,
Sharkcutup and I have been busy these last few days and made a few additions to the Easy Cabinet maker.
Here is version 13 and will only work within version 11+ of the VCarve Pro or Aspire.
Supports:
Version 11+ VCarve Pro or Aspire.
Enhancements:
1. Create sheets for different thickness parts (SDK doesn't support setting sheet material thickness)
2. Added drawer slides pilot holes for the cabinet sides and back (this includes a user interface to edit, create new slides)
3. Error trapping and many more features and functions.
Next Steps:
Updating the Help Files
Welcome any feedback.
EasyCabinetMaker.zip
Rename to: EasyCabinetMaker.vagdget
(466.94 KiB) Downloaded 124 times
Jim
dyn0bill
Model of CNC Machine: EZ Route 4x8/WinCNC
Post by dyn0bill »
Jimbo,
How are you? I just noticed you have rev 12.1 out. I will give it a look.
I was going to make a bathroom vanity but in order to do that the horizontal pieces that tie the sides together need moved to the vertical faces in order for the sink top to fit.
Just a suggestion.
Willy
dyn0bill
Post by dyn0bill »
Jimbo,
I just saw rev 13 is out.
Willy
jimandi5000
dyn0bill wrote:
Wed Jan 05, 2022 1:10 am
Jimbo,
Willy
Thanks Willy, Have a look at the new pdf Help file that is in the gadget folder. I am working on updating the help links.
Jim
dyn0bill
Post by dyn0bill »
Jimbo,
I don't see a pdf anywhere?
Willy
sharkcutup
Post by sharkcutup »
Willy Look Here: viewtopic.php?p=283979#p283979
Sharkcutup
V-Carve Pro 12.004
jimandi5000
Hello everyone,
I believe it is finished. Attached you will find a copy of the Version 13.5 of the Easy Cabinet Maker.
This is the most complete, most comprehensive, and most tested version of the gadget.
Due to the size of the PDF file, I am unable to included in the gadget installation package. You'll need to download it directly from:
https://www.jimandi.com/EasyGadgets/Eas ... tMaker.pdf
Supports: Vectric aspire and VCarve Pro 11.0+ only
Enhancements List:
  • 49 page user guide
  • User editable Materials and Finishes ini file
  • Corrected pilot hole for Drawer Slides
  • Improved hardware management logic
  • So many others I can't remember.
Unless someone finds an error, I have no plans for new modifications to this gadget.
Special thanks to Sharkcutup for all of his feedback, encouragement, suggestions, guidance, reviewing, proofing, testing and support.
Rename to: EasyCabinetMaker.vgadget
(512.44 KiB) Downloaded 131 times
Jim
cusoak
Post by cusoak »
how do I find the installation file to be able to install the program I looked through the pdf and did not see it.
probably because I did not know what to look for. I looked through the pdf and it looks great want to get it installed and and start to us it
Thanks for all your heard work.
Jeff Peters
scotttarnor
Post by scotttarnor »
The zip file is in the post above yours.
Scott T
@scottscnc
jimandi5000
cusoak wrote:
Sun Jan 23, 2022 1:23 pm
Jeff Peters
Hi Jeff,
Download the zip file and rename to EasyCabinetMaker.vgadget. Open Vectric and go to Gadgets and run the load the downloaded gadget.
Hope this helps.
Jim
dyn0bill
Post by dyn0bill »
Jimbo,
Gracias, I downloaded 13.5 and installed it without a problem. I also downloaded the pdf of the documentation.
I like my docs printed, do you have any plans to create any printable(portrait) docs? Did you use power point to create the pdf?
I think I asked you if you could create an option to create a bathroom cabinet that a sink top fits on?
Once again, thank you for the gadget. It is amazing.
Willy
jimandi5000
dyn0bill wrote:
Mon Jan 24, 2022 12:08 am
Jimbo,
Willy
Hi Willy,
Yes, I am working on the Word (pdf) version of the help file. I know I did not make it real clear but the PowerPoint version is more of a user guide. The Word version I am working on I am trying to go into more detail on each Input item.
Can you sent me a drawing of what you are thinking of and what questions you would be looking at?
Jim
dyn0bill
Post by dyn0bill »
Jimbo,
Picture of a bath vanity. I don't know the names of the top pieces that span the cabinet.
Willy
Vertical pieces
Vertical pieces
cusoak
Post by cusoak »
jim when might the word version pdf be done.
I want to thank you for all your hard work in putting together the cabinet gadget along with the easy MDF door maker.
I build custom cabinets for a Remodeler .
Your program will save me a lot of time how long did it take you to get the cabinet maker to where it is today
Thanks Jeff Peters
jimandi5000
cusoak wrote:
Tue Jan 25, 2022 11:58 am
Thanks Jeff Peters
Hi Jeff,
I am at page 47 and looks like I am about 40% done... say a week or two more?
Your very welcome for the gadget. This project has help me. all of you guy (and girls) have been a great support and motivators.
Jim
