Easy Cabinet Maker
jimandi5000
Re: Easy Cabinet Maker
Post by jimandi5000 »
Hello boys and girls,
Sharkcutup and I have been busy these last few days and made a few additions to the Easy Cabinet maker.
Here is version 13 and will only work within version 11+ of the VCarve Pro or Aspire.
Supports:
Version 11+ VCarve Pro or Aspire.
Enhancements:
1. Create sheets for different thickness parts (SDK doesn't support setting sheet material thickness)
2. Added drawer slides pilot holes for the cabinet sides and back (this includes a user interface to edit, create new slides)
3. Error trapping and many more features and functions.
Next Steps:
Updating the Help Files
Welcome any feedback.
EasyCabinetMaker.zip
Rename to: EasyCabinetMaker.vagdget
(466.94 KiB) Downloaded 38 times
Jim
dyn0bill
Model of CNC Machine: EZ Route 4x8/WinCNC
Post by dyn0bill »
Jimbo,
How are you? I just noticed you have rev 12.1 out. I will give it a look.
I was going to make a bathroom vanity but in order to do that the horizontal pieces that tie the sides together need moved to the vertical faces in order for the sink top to fit.
Just a suggestion.
Willy
dyn0bill
Post by dyn0bill »
Jimbo,
I just saw rev 13 is out.
Willy
jimandi5000
dyn0bill wrote:
Wed Jan 05, 2022 1:10 am
Jimbo,
Willy
Thanks Willy, Have a look at the new pdf Help file that is in the gadget folder. I am working on updating the help links.
Jim
dyn0bill
Post by dyn0bill »
Jimbo,
I don't see a pdf anywhere?
Willy
sharkcutup
Post by sharkcutup »
Willy Look Here: viewtopic.php?p=283979#p283979
Sharkcutup
Hogan's CNC Crafts
One on One V-Carve Help is Available!!!
PM me for details!
V-Carve Pro 11.010
jimandi5000
Hello everyone,
I believe it is finished. Attached you will find a copy of the Version 13.5 of the Easy Cabinet Maker.
This is the most complete, most comprehensive, and most tested version of the gadget.
Due to the size of the PDF file, I am unable to included in the gadget installation package. You'll need to download it directly from:
https://www.jimandi.com/EasyGadgets/Eas ... tMaker.pdf
Supports: Vectric aspire and VCarve Pro 11.0+ only
Enhancements List:
  • 49 page user guide
  • User editable Materials and Finishes ini file
  • Corrected pilot hole for Drawer Slides
  • Improved hardware management logic
  • So many others I can't remember.
Unless someone finds an error, I have no plans for new modifications to this gadget.
Special thanks to Sharkcutup for all of his feedback, encouragement, suggestions, guidance, reviewing, proofing, testing and support.
Rename to: EasyCabinetMaker.vgadget
(512.44 KiB) Downloaded 12 times
Jim
