Easy Cabinet Maker
dyn0bill
Model of CNC Machine: EZ Route 4x8/WinCNC
Re: Easy Cabinet Maker
Post by dyn0bill »
Jimbo,
Faster horses, younger women and better drugs!
No problem with the double milling.
Willy
mrramsey1969
Model of CNC Machine: ShopSabre Pro404
Post by mrramsey1969 »
Hey Jim!
First off Kudos to you! This gadget is great!
I did find a small bug with the face frames though. Not that I am milling face frames but I do like the reference. It draws them at the full height of the cabinet which is fine for the wall cabs but not the base cabinets :) There is also a typo "Shelf End Clarence" :wink:
jimandi5000
Post by jimandi5000 »
Howdy everybody,
I was able to fix the cabinet gadget issues with the Wall Cabinet back panel. So here's the new version EasyCabinetMakerVer11.6 gadget with some new features as well.
Errors Fixed:
1. Back panel length calculation
2. Top and bottom rabbit not being drawn and toolpath applied if center panel was not added
3. Spelling errors
New Features:
1. Export all (205+) user settings of current cabinet configuration
2. Import a selected previous export file.
Supports: Vectric Aspire and V Carve Pro versions 10+
Next Steps:
1. Update Help Files
2. Add some more error trapping
EasyCabinetMakerVer11.6.zip
Rename to: EasyCabinetMakerVer11.6.vgadget
(54.28 KiB) Downloaded 13 times
Ini File of Cabinet Settings
Ini File located with Bill of Mat Files (Note date(yyyymmddhhmm) added to file name)
Added Import and Export buttons
Enter a file name to Export (Cabinet Name is the Default)
Select file to Import
Jim
jimandi5000
Howdy everybody,
I hope your day is full of joy happiness.
I fixed the Easy Cabinet Gadget base face frame issues. So here's the new version EasyCabinetMakerVer11.7 gadget with some new features as well.
Error Fixed:
1. Base Face Frame length calculation
New Features:
1. Error trapping on Import and Exporting files
2. New Sheet selection is disabled for Vectric version 11 and above
3. Updated Help Files on all changes
4. Added folders inside the vgadget load file. This will show up in the Gadget pull down menu.
Supports:
Next Steps:
1. Add an option to place Drill holes for screws in sides panels for cabinet assembly
2. I may make a video on how to use the gadget? (let me know if you want one)
Any issues or request?
EasyCabinetMaker.zip
Rename to: EasyCabinetMaker.vgadget
(54.78 KiB) Downloaded 11 times
Jim
dyn0bill
Post by dyn0bill »
Howdy Jimbo,
Happy Thanksgiving!
I will give the new version a try, I am sure you have made some positive changes.
I think a video would be great! Save some time learning the gadget.
'til Valhalla
Willy
jimandi5000
dyn0bill wrote:
Thu Nov 25, 2021 3:21 am
Howdy Jimbo,
Happy Thanksgiving!
'til Valhalla
Willy
Thanks Willy. I will finish the the pilot hole up grade and start working with the script for a how to video.
Jim
dyn0bill
Post by dyn0bill »
Jimbo,
If I can be of any help with the video, or anything, let me know.
Willy
My machine
My machine
jimandi5000
dyn0bill wrote:
Thu Nov 25, 2021 6:50 am
Jimbo,
Willy
will do on the help. And may I say that is a nice CNC Mill you got there...
Jim
jimandi5000
Howdy everybody,
Great Joy and happiness to you and your families on this Thanksgiving day.
I've been going through the Easy Cabinet Gadget code in great detail. I have a new version of the EasyCabinetMakerVer11.8 gadget with a number of fixes and some new features.
Error Fixed:
1. Base - Toe kick width was incorrect
2. Base - Top stretch width was incorrect
3. Part identification callout and Bill of materials had some parts width and length inverted values (Toe kick, Stretchers and Bottom)
New Features:
1. Added (optional) Assembly Pilot Holes (Base and or Wall cabinets)
2. Modified milling dialogue for options on Assembly pilot holes
3. Updated main dialogue for assembly pilot hole bit selection for the toolpath
Supports:
Next Steps:
1. Update help files to reflect the new enhancements
2. Make a YouTube video on how to use this gadget
(57.34 KiB) Downloaded 5 times
Jim
dyn0bill
Post by dyn0bill »
Jimbo,
Many thanks for your effort!
How do I remove the older rev's of Easy Cabinet Maker?
My gadget list is getting crowded.
Willy
Post by adze_cnc »
For Windows 10 (and presumably recent previous versions of Windows) you can find them at:
Code: Select all
C:\Users\Public\Documents\Vectric Files\Gadgets
Within that will be your product (Aspire or VCarve) and within that the old versions of Easy Cabinet Maker that you no longer need.
jimandi5000
Howdy everybody,
I hope you are having a great day.
I received a message on my latest update that some of the Assembly Pilot Holes were doubled up (sitting directly on top of each other).
It was a quick fix and wish I had caught it before I posted.
Please find the attached zip file containing EasyCabinetMaker Version 11.9
Error Fixed:
1. Double stacked Assembly Pilot Holes
Supports:
Next Steps:
2. Make a "How To" video on this gadget
(57.21 KiB) Downloaded 14 times
Jim
dyn0bill
Post by dyn0bill »
Thanks Jimbo,
I will take a look at it as soon as I get my server back up.
Attached is a variation of the boxes I suggested for a gadget consideration. I realize it is really just boxes but could be built like a cabinet.
a variation on the boxes I suggested for gadget creation.
We sure need a cabinet door gadget using VCarve and staying within a certain spec.
Carpe diem
Willy
jimandi5000
Willy,
"We sure need a cabinet door gadget using VCarve and staying within a certain spec."
Let me see some spec's...
Have you seen this post?
viewtopic.php?f=51&t=37869
Jim
