Drawer Maker
jimandi5000
Re: Drawer Maker
Post by jimandi5000 »
Hello All,
I hope you are have some fun today!
I have added the grouping function to the Notes and Part Numbers to the Easy Draw Maker Version 3.5. This should make it easier to move the test.
Supports: Vectric 10+
Jim
jimandi5000
Re: Drawer Maker
jimandi5000 wrote:
Wed Sep 22, 2021 4:04 pm
Hello All,
I got a HTML Error on the Attachment.
EasyDrawerToolsVer03.5.zip
Rename to: EasyDrawerToolsVer03.5.vgadget
(32.67 KiB) Downloaded 336 times
Jim
mrramsey1969
Model of CNC Machine: ShopSabre Pro404
Re: Drawer Maker
Post by mrramsey1969 »
I am trying to use the Drawer Maker Gadget but run into an issue that it is creating the objects off of my sheet. I am trying to create a single drawer
jimandi5000
Re: Drawer Maker
mrramsey1969 wrote:
Sat Oct 16, 2021 5:36 pm
Hi Mr Ramsey1969,
As you may know the gadget was designed to support multiple material thicknesses and draw the drawer parts on the material thickness sheet. The recent changes in Vectric version 11 has changed their Sheet functionality and has not provided a SDK update to control the new function. Therefore, I found it necessary to disable the sheet creation functions and draw each part based on its material thickness in a location where it is separate from the other parts.
For instance, if you were to draw a drawer with a 1" thick front, 3/4" of an inch sides, a 1/2" back, and 1/4" bottom. The gadget would produce for sheets one sheet for each material thickness. As necessary because the milling is different based on material thicknesses.
I hope this helps and please let me know if you have other questions.
Jim
mrramsey1969
Re: Drawer Maker
jimandi5000 wrote:
Sun Oct 17, 2021 3:50 pm
Hi Mr Ramsey1969,
Hi Jim,
Thanks for the reply! That makes sense. I was finally able to generate the parts correctly. Hopefully Vectric will get you the update to the SDK soon!
gregk
Model of CNC Machine: None
Re: Drawer Maker
Post by gregk »
A new version of the SDK has been released: https://gadgets.vectric.com/v11/gadget-sdk
Greg K
jimandi5000
Re: Drawer Maker
gregk wrote:
Tue Oct 19, 2021 1:54 pm
Greg K
Thanks Greg!
I now have something to work on. :)
Jim
jimandi5000
Re: Drawer Maker
Hi there all,
Here is the Easy Drawer Maker 4.0 and it will only work on Version 11+ of VCarve or Aspire.
EasyDrawerMakerVer4.0.zip
Rename to: EasyDrawerMakerVer4.0.vgadget
(33.63 KiB) Downloaded 162 times
C1-202201051314.zip
BOM (dat and csv) files
(750 Bytes) Downloaded 111 times
Jim
