Easy MDF Cabinet Door Maker
- jimandi5000
The other day, I was asked if I could write a "simple" gadget to layout cabinet door faces. These doors would be cut out of MDF material. These are relatively simple doors with about six styles of panels. I was also ask, if I could incorporate some fluting for each style (horizontal and vertical) that would be recessed inside the panel.
Well, as you know, nothing is just simple. After getting some feedback from a expert (you know who you are)... I have added a few features:
1. Reads a CSV file for batch processing.
2. It cam make ad hoc doors from the main dialogue
3. When a door is too small to be drawn correctly it writes a log file (same place as CSV file)
4. Remembers your last inputs
5. Supports both metric and imperial.
6. Somewhat of an online help.
7. Last but not least, pretty strong error trapping
I know everyone is not crazy about making cabinet doors. But if you're interested in writing your own gadgets, you deftly could leverage the source code. There is a little over 1800 lines of code here and as always if you have questions I'm happy to help.
I'm thinking this gadget is pretty close to being done one. So, If you feel up to it, download and install the gadget and test drive it. If you have some time provide some feedback on what works and what doesn't... That would be great.
Happy Milling
Jim
Jim
- mtylerfl
Re: Easy MDF Cabinet Door Maker
Wow, Jim!
- jimandi5000
OMG.... I missed updating the URl for the help...
If you want here is the correct one.
On line 49 of the code it reads"
Should read
DialogWindow.ProjectSDK = "https://github.com/JimAndI"
Should read
DialogWindow.ProjectSDK = "https://github.com/JimAndI/EasyMDFDoorMaker/wiki"
Jim
Jim
- jimandi5000
Okay, Okay, You knew it was coming...
I have fixed the help file issue. Here is Version 7.0
- EasyMDFDoorMaker_Ver07.zip
- Rename to EasyMDFDoorMaker_Ver07.vgadget
- (908.68 KiB) Downloaded 448 times
Jim
Jim
- gkas
Thanks Jim....
- jimandi5000
- jimandi5000
Hello All,
I hope your shop floor is clean and your sawdust can is full.
Thanks to Ben and his great work in testing this gadget. I am happy to say it is DONE!!!!
Happy milling.
The list:
1. New web Help
2. More error trapping
3. Better door panel failure logs
Happy milling.
The list:
1. New web Help
- EasyMDFDoorMaker_Ver10.2.zip
- Rename to: EasyMDFDoorMaker_Ver10.2.vgadget
- (51.78 KiB) Downloaded 499 times
Jim
Jim
- jimandi5000
Jim
Jim
- BenjaminwithCNC
- Model of CNC Machine: Danibrum 1325 ATC Rotary 4x1
There are not many, but those that use this Gadget know... it helps a very lot
Thank you Jimandi
Thank you Jimandi
- jimandi5000
Super!!! Happy to helpBenjaminwithCNC wrote: ↑Thu Jul 22, 2021 6:36 amThere are not many, but those that use this Gadget know... it helps a very lot
Thank you Jimandi
Jim
Jim
Jim,
I really appreciate your hard work. Thank you!
- jimandi5000
- Model of CNC Machine: Shapeoko 3D XXL
what do I need to do to install the easy MDF door maker version 10.2
Thanks Jeff
Thanks Jeff
- Model of CNC Machine: Avid Pro 48x48
Would appreciate some guidance on using this - not working for me.
Downloaded the file
Extracted the .lua (7zip)
Renamed the .lua file to EasyMDFDoorMaker_Ver10.2.vgadget
In VCarve Pro (11.009) :
Gadgets
Install New Gadget...
Navigated to and selected the renamed file
Error: Failed to Install Gadget
Downloaded the file
Gadgets
"If the women don't find you handsome, they should at least find you handy."
Red Green
Red Green
- adze_cnc
do not unzip the zip file. rename the zip file to .vgadget
