Easy Cabinet Maker
jimandi5000
Re: Easy Cabinet Maker
Post by jimandi5000 »
Hello All,
I have a new version 10-9.0 of the Easy Cabinet Maker.
I have added material block logic to the gadget. (thanks Willy) This additional code will determine if you have the material in a horizontal or vertical position and determine where the XY Datum Origin Point is located ie. top left, top right, bottom left, bottom right or center. I would not recommend using the material center for the origin point, you will have mainly manipulate the cabinet components on the drawing in order to get parts to fit properly on the material.
I will continue to work on the documentation (documentation is a much larger part of the project than I was anticipating) and as always, I welcome your feedback, suggestions or if you find errors.
Here is the link to the download page?
http://www.jimandi.com/EasyGadgets/Easy ... Maker.html
Jim
dyn0bill
Model of CNC Machine: EZ Route 4x8/WinCNC
Post by dyn0bill »
Jim,
Thanks for the help. What tools are used to create gadgets? Are they a script of some sort?
Willy
dyn0bill
Post by dyn0bill »
Jim,
The link is giving me a 404 error;
Not Found
The requested URL was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
dyn0bill
Post by dyn0bill »
Jim,
I was able to get to the download page by backing up and selecting the directory.
Willy
jimandi5000
dyn0bill wrote:
Sat Mar 13, 2021 8:18 pm
Jim,
Willy
Hi Willy,
Found the error in the url:
This one should work. :)
Jim
dyn0bill
Post by dyn0bill »
Jim,
I can't seem to find 10.9?
All I get is 10.8.3 which has nothing about changing the orientation?
Willy
jimandi5000
dyn0bill wrote:
Sun Mar 14, 2021 8:18 am
Jim,
Willy
Hi Willy,
I have been working on the web site all day.... Please try now. You should see the Version 10-9.1 with new help pages (please note these are under construction and not complete) but the application should work fine.
please let me know.
Jim
dyn0bill
Post by dyn0bill »
Thanks Jim,
I looks like it is working correctly now.
I have never worked with sheets before.
Pretty impressive program!
Willy.
jimandi5000
Super!!!
Jim
bobgob
Model of CNC Machine: Avid
Post by bobgob »
Jim, are you still making Easy Cabinet Maker available? I've tried your website a few times and it says that it is under maintenance.
I'm writing a cabinet gadget and so far I have the case done. I was about to start on drawers and discovered your post here.
Another option I was looking at was modifying the Vectric Box Creator gadget but there is a lot of code there I would want to strip out plus modifying the bottom for a dado.
I'm looking to do simple boxes for the drawers, box joint sides with dado on the bottom.
My cabinets are simple. Sides are two dado's (for top and bottom) and a rabbet for the back, plus adjustable shelf holes. Top and bottom are two rabbets on each side to mate with the case sides plus one on the flip side for the case back.
jimandi5000
Hi Bobgob,
Yes, all my gadgets available. Here is the most current cabinet gadget version.
EasyCabinetMaker.zip
(346.72 KiB) Downloaded 238 times
Jim
bobgob
Post by bobgob »
Hi Jim,
Thank you for sharing! Have you had any thoughts about drawers or do you use the Vectric Box Creator gadget?
jimandi5000
bobgob wrote:
Wed Apr 21, 2021 4:25 am
Hi Jim,
Here is my drawer gadget.
EasyDrawerMaker.zip
(53.59 KiB) Downloaded 215 times
Jim
Post by Rcnewcomb »
Is the web site still being developed? I'm unable to connect.
jimandi5000
Rcnewcomb wrote:
Mon Jul 12, 2021 3:40 pm
Sorry, after becoming disabled, I can't afford keeping the JimAndI.com web site and had to turn it off. I am rethinking the help solution gadgets. I should have something coming out soon.
Until I have something, I am happy to help with any questions.
Jim
