Fishy stuff
- Model of CNC Machine: Avid CNC
Fishy stuff
Hi - first posting so I thought I'd show my latest work to test the waters.
I have a large resin encapsulation planned and have only used polyester in the past so needed a test piece to get familiar with epoxy. I had a ceramic head, tail and pectoral fins of a fish kindly made by my partner but no body so it was ideal. I made the enclosure out of White Mahogany with the "waste" section from the profile toolpath as the base. I sat the enclosure on a waxed rubber base for the first pour and when it was hard I removed the rubber and proceeded with the next pour. When the enclosure was half full with the head half embedded and the resin hard I V-carved the skeleton into the resin surface (very, very carefully in order to not damage the embedded head) and my partner inked it in using acrylic inks (she is much better at detailed painting than me). The remainder of the pour was then completed with darkly tinted resin. Because the resin surface which had been in contact with the rubber base was a matt finish I then flipped the now full enclosure over, pocketed out the resin a couple of mm deep and filled it with clear coating epoxy to get a nice shiny clear surface. The graphics on the base were designed in VCarve Pro and toolpathed using the Laser Module. This was the first time I'd tried a wraparound design and it went really well. The piece is called "Ish Pish Littlefish".
Overall it turned out pretty well and gave me the confidence to start on the larger encapsulation - a ceramic Weedy Sea Dragon sculpture done by my partner embedded in a faux bronze porthole (assembled out of ply parts cut on the CNC).
Greg
Avid CNC spindle/laser/plasma hybrid
- scotttarnor
Re: Fishy stuff
Really nice project and the outcome looks great. One of my first projects in cnc was carving a fish skeleton in a chunk of pine wood I cut from a log. My wife is very possessive of it.
Re: Fishy stuff
Very Nice.
Gary
Gary
- Todd Bailey
- Vectric Staff
- Model of CNC Machine: CraftCNC
Re: Fishy stuff
What a fun project!!! I really love it.
Thanks for sharing!!!
Todd Bailey | Design and Make
DesignAndMake.com
DesignAndMake.com
- Model of CNC Machine: China CNCZOne 6040 4 axis
Re: Fishy stuff
What a great idea and well executed, I am pretty sure my son in law would swap his tropical fish tank for one of them.
- Model of CNC Machine: Next Wave Piranha XL
Re: Fishy stuff
Impressive! Very well done. Be sure to post the seahorse when completed.
Steve Harp
Wadsworth, Ohio USA
www.trlw.us
Wadsworth, Ohio USA
www.trlw.us
Re: Fishy stuff
Thanks everyone for the kind comments.
Yes I think fish are a great subject for CNC work - no fiddly legs!Savannahdan wrote: ↑Thu Feb 23, 2023 12:39 pmReally nice project and the outcome looks great. One of my first projects in cnc was carving a fish skeleton in a chunk of pine wood I cut from a log. My wife is very possessive of it.
I will post the sea dragon when it's done. At the moment it's giving me headaches as the final resin pour has just clouded a bit and it looks like I might have to machine that layer out and repour with a different resin Oh well, as Deadpool might say "maximum effort".Luvtocarve wrote: ↑Mon Feb 27, 2023 10:04 pmImpressive! Very well done. Be sure to post the seahorse when completed.
Greg
Re: Fishy stuff
It's a weedy - no way my partner was going to try making a leafy out of clay. As it was the weedy dropped off various appendages on a regular basis which had to be epoxied back on. It was a bit like wack-a-mole - glue one bit on and in the process knock another off. In fact the fragility of the completed piece gave rise to the decision to encapsulate it. I defy it to keep shedding while buried in resin!
Greg
- jfederer
- Model of CNC Machine: CanCam D23M
Re: Fishy stuff
Brilliant work! Your process opens up my own projects to new possibilities. Thank you!
Joe Federer
www.federer.ca
www.federer.ca
Re: Fishy stuff
Thanks for the support Joe. Yes incorporating resin in your CNC mindset really opens up lots of creative doors.
Re the weedy seadragon - it's on the wall and we are both pretty happy with it. I'll put up a separate post for it .
Greg
- scottp55
Re: Fishy stuff
VERY well done!!
My congratulations!
Reminds me of a couple years ago,
my desire to do a whale skeleton fossil carve in soapstone from the Smithsonian's collection of scanned objects.
https://3d.si.edu/explore
May get around to it this year.
My congratulations!
R.N.
R.N.
Re: Fishy stuff
Hi Scott - the whale skeleton would be pretty funky especially in soapstone.scottp55 wrote: ↑Sun Mar 05, 2023 5:41 pmReminds me of a couple years ago,
Yeah I know the feeling - so many things to do - so little time.
Greg
