Granit Vcarving
manufv
Model of CNC Machine: Stepcraft D-840
Granit Vcarving
Post by manufv »
A job with cnc Stepcraft D840, spindle HS500, vbit PCD Ø6x60°x0,4mm for marble / granit. Runtime 4h
Granit Vcarve
Granit Vcarve
Bobtail Farm
Re: Granit Vcarving
Post by Bobtail Farm »
swell result.
Todd Bailey
Vectric Staff
Model of CNC Machine: CraftCNC
Re: Granit Vcarving
Post by Todd Bailey »
Looks great!!!
I have always wanted to give v-carving into granite/slate a try.
Could you share a bit more info on the vbit you used?
Thanks for sharing!
Todd Bailey | Design and Make
DesignAndMake.com
scottp55
Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP11.5
Re: Granit Vcarving
Post by scottp55 »
+1 on the bit info and your feeds/speeds/depth of pass please.
(I told a member I wouldn't try it as a dry cut :oops: :oops: )
R.N.
manufv
Re: Granit Vcarving
Post by manufv »
For these job, I use :
Toolpath Type: V-Carve / Engraving Toolpath
Feed Rate: 4 mm/sec
Plunge Rate: 0.5 mm/sec
Spindle Speed: 18000
Pass Depth: 0.4mm
Stepover: 0.16mm
Tool Notes:
Fraise PCD Ø6x60°x0,4mm pour marbre / granit
PCD (polycrystalline diamond) engraving bit Ø6x60°x0,4mm for marble/granite
https://www.gravierbedarf.de/epages/632 ... ducts/1402
I work with water bath, the stone is under water.
The real difficulty is to check that the width of the paths is greater than 0.4mm.
Regards
