Astrolabe
- TomWS
- Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Re: Astrolabe
Wow! What a beautiful instrument! I have no idea what that would be used for, but the workmanship would guarantee a place in anyone's display case!
- scottp55
Re: Astrolabe
Wow! +1
VERY impressed with your attention to detail and craftsmanship!!
Very well done!
My congrats.
Very well done!
My congrats.
R.N.
R.N.
Re: Astrolabe
Very Impressive. How did you do the print?
Gary
Gary
Re: Astrolabe
The letters and numbers are engraved on wood and plastic. The plastic has a layer of color apx .004" thick. The engraving bit cuts through that layer to white or black plastic beneath. The wood is engraved and then painted over with black paint and excess sanded off.
- AboveCreations
- Model of CNC Machine: i2r B22
Re: Astrolabe
I am in agreement... that is some mighty fine craftmanship, indeed. Thanks for the explanation on the engraving process. I assume that wood is oak or something very hard?
Re: Astrolabe
I know what material you were using. I made and donated plaques for Eighty-Eight Universities across the nation for the Sigma Lambda Chi Honor Society for Construction Management. However I used the Laser Engraver rather than the CNC machine. The metal insignia I modeled in Aspire and had them casted in metal by a supplier out of China.The letters and numbers are engraved on wood and plastic. The plastic has a layer of color apx .004" thick. The engraving bit cuts through that layer to white or black plastic beneath. The wood is engraved and then painted over with black paint and excess sanded off.
Gary
Re: Astrolabe
I used a piece of ply (thin veneer on front and back with an MDF center). Not sure what the thin veneer is as I got the piece from a friend, who got it from a friend........ the stand (pictured below) is European Beech. I used a Precise Bits engraver (30 degree) and set the depth for .009" using the engraving tool in VCarve Pro with fill option.AboveCreations wrote: ↑Tue Nov 16, 2021 6:14 amI am in agreement... that is some mighty fine craftmanship, indeed. Thanks for the explanation on the engraving process. I assume that wood is oak or something very hard?
Re: Astrolabe
Very nice Gary. Can you tell us the company in China that cast the metal part?garylmast wrote: ↑Tue Nov 16, 2021 2:20 pmI know what material you were using. I made and donated plaques for Eighty-Eight Universities across the nation for the Sigma Lambda Chi Honor Society for Construction Management. However I used the Laser Engraver rather than the CNC machine. The metal insignia I modeled in Aspire and had them casted in metal by a supplier out of China.The letters and numbers are engraved on wood and plastic. The plastic has a layer of color apx .004" thick. The engraving bit cuts through that layer to white or black plastic beneath. The wood is engraved and then painted over with black paint and excess sanded off.
Gary
Re: Astrolabe
Sorry, it's been over three-years since I've did these and I don't remember the name of the company. After google search, I remember getting a couple of quotes from companies in the U.S. and for a minimum of 100 it was somewhere around $5,000. The company in China ended up be under $1000 for a hundred of them.
Gary
- Model of CNC Machine: Next Wave Piranha XL
