I finally made my first foray into 3D Carving by making this Corian top for a simple turned box.
The top uses the Magnolia Flower from the ClipArt library with the beaded perimeter and dish effect made using a moulding toolpath. The moulding toolpath and rouging clearance was cut with an 1/8" ball nose bit while the 3D Flower was cut with a 0.5mm radius tapered ball nose using a 0.0032 inch stepover.
I used a two sided technique to align the routed inside of the top. For the outline profile and the inside pocket I used an 1/8" O-Flute bit.
The routing went extremely well with the only cleanup work required was on the edge of the top where I had four holding tabs. This I turned on the wood lathe with a negative rake, 2R, Easy Wood tool.
The wood is Butternut hacked out of a scrap I had 'saved' from a firewood pile.
SimpleTurned Box made elegant
- scottp55
Re: SimpleTurned Box made elegant
A lot better than My first 3D!
Welcome to 3D....BUT it can be addictive!!
LOVE your "Firewood"!!
Nice!:)
Nice!:)
R.N.
R.N.
- SteveNelson46
- TomWS
- Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Thanks Scott and Steve! It was your contributions that made it a lot easier for me!
- Model of CNC Machine: Axiom AR 8 Pro+
That is a really nice looking piece of work, Tom. The Corian goes well with that wood.
- Todd Bailey
- Vectric Staff
- Model of CNC Machine: CraftCNC
Love the two materials!!!! Looks very nice!!! Thanks for sharing!
Todd Bailey | Design and Make
DesignAndMake.com
DesignAndMake.com
