Another one of my simple utilitarian projects.
The problem to solve was keeping the most used implements on the table of our 5th wheel trailer while traveling. Kind of annoying to rummage through various drawers and cabinets just to fetch the salt, sugar, maple syrup etc every time you stop. Obviously you can not just leave it sitting there.
So I designed this rack as a bumpy-road proof holder for said implements. Made from a 4x4 piece of redwood fence post (actual size 3.5"x3.5"x23"). I had that sitting in my shop for several years so it was well-dried. The challenge was the 3.25" deep 3d-carve and I used a 6" long ballnose bit (1/2" dia) with 3" long flutes. The raw wood was screwed onto a plywood carrier plate from below with 10 small screws in locations I knew would not be machined away. I did not trust my vacuum pod system to hold that tall piece being machined with a large bit at high speed and since the wood is used 100%, there is no waste to use clamps. All vertical surfaces of the 3-d model are tapered 2 degrees to avoid the bit slamming into vertical walls.
Came out quite well. I did not use a 3d-roughing pass but hogged out the pits roughly with a pocket toopath. Unfortunately I had to use the ballnose bit for that as well because it is the only bit in my possession that is as long. But roughing with a big ballnose protruding that far is not ideal and I had to dial in the spindle speed by ear to avoid resonance and chattering. For this project I needed almost all of the 8" z-travel of my machine.
That how it looks when loaded. The redwood is not great for carving, just too soft/brittle and prone to tear-out. But nothing that can not be fixed with a random orbital sander....Finish is semi-gloss PU.
The rack will be attached by double sided tape to the trailer table next to the window.
Glass/Jar/Shaker Holder
- scotttarnor
Re: Glass/Jar/Shaker Holder
That looks good! Nice explanation of the process also Thank You!
Scott T
@scottscnc
@scottscnc
- Model of CNC Machine: Next Wave Piranha XL
Nice design and useful. Unfortunately my machine won't handle a bit that size.
Steve Harp
Wadsworth, Ohio USA
www.trlw.us
Wadsworth, Ohio USA
www.trlw.us
- Todd Bailey
- Vectric Staff
- Model of CNC Machine: CraftCNC
Great idea!!!!
Thanks for sharing... got me thinking!!!
Todd Bailey | Design and Make
DesignAndMake.com
DesignAndMake.com
