fraction to decimal chart
- jimandi5000
Hello All,
I just made this and was thinking you all may want to make one in your shop.
It is 0.5 x 20 x 30 MDF.
Have a look.
Have a look.
- FracDecMMTablex.zip
- (429.94 KiB) Downloaded 472 times
Jim
Jim
- highpockets
- Tex_Lawrence
Re: fraction to decimal chart
Jim, when you add too many decimal places, sometimes you introduce a problem.
For instance, "1/2 = 0.500000 - 12.7001" or "1 = 1.000000 - 25.4001". There are others. Looks like your data source rounded up occationally.
Yes, I'm being pedantic, but you put it out there for all to see!
It looks like its a well made chart. +1 I've been needing one while converting a couple of projects from Imperial to metric.
Tex — Crooked Wood Products
Here's a PDF file that I keep on my desktop, that I posted a couple of times. I refer to it constantly.
Gary
Gary
- Fraction - Decimal - mm table.pdf
- (42.79 KiB) Downloaded 396 times
- Model of CNC Machine: CNC Shark Pro Plus
1 inch has been equal to 25.4 mm exactly my whole life. Has climate change caused it to grow another 0.0001 mm?
BillK
https://www.facebook.com/CarvingsByKurtz
- jimandi5000
Hi all, i found an error in the excel sheet. It was adding a rounding up error. I will repost the files.
Jim
Jim
- jimandi5000
Hello All,
Fixed the draw...
Have some fun.
Fixed the draw...
Have some fun.
- FracDecMMTablez.zip
- (373.48 KiB) Downloaded 275 times
Jim
Jim
- Tex_Lawrence
Pedantic crisis averted! I'm liking it more!
I would be using my 30 deg. engraving bit and a single line font. Then I would duplicate toolpaths and add 0.001" or 0.002" to the depth each time. Maybe two cleanup passes depending on what wood you're using.
Those letters are going to be difficult to clean otherwise, and there's a LOT of them.
- jimandi5000
Tex_Lawrence wrote: ↑Sat Mar 20, 2021 10:29 pmPedantic crisis averted! I'm liking it more!
- Nailed IT.png (23.28 KiB) Viewed 5174 times
Jim
Jim
- Model of CNC Machine: Next Wave Shark HD4
Just carved one for my shop. Thanks for all the work you put into this. Not sure that I would have gone to all of the trouble if you hadn't done all the hard stuff. Did it simple with 1/4 inch plywood. Carved with 60 degree V Pencil Point bit. Looks great.
- jimandi5000
Good to hear you made one. I have made about 10 of them as gifts. I used Timbermate Walnut Hardwood Wood filler to make the letters pop.ronaldgsims wrote: ↑Thu Jul 01, 2021 11:59 pmJust carved one for my shop. Thanks for all the work you put into this. Not sure that I would have gone to all of the trouble if you hadn't done all the hard stuff. Did it simple with 1/4 inch plywood. Carved with 60 degree V Pencil Point bit. Looks great.
Jim
Jim
What a great solution to make the numbers and letters pop. I have always just masked and painted followed by lots and lots of sanding. I'll look for the filler and try it the next time I carve anything like this.
- FixitMike
If you use a dark wood filler (or stain) to make the letters "pop", don't use cherry for the base material. After a few years of exposure to light it gets quite dark and the contrast will be lost. Don't ask.
- Tex_Lawrence
Along with what FixItMike says and while sanding off the wood filler, don't forget that you did all of this on a scrap piece of cheap plywood.
It doesn't have much of a top veneer. Oops!
- jimandi5000
