I have been wanting to make a full sized sculpture but with lumber prices the way they are I had to settle for a head. Made from 3/16" plywood and 60 to 70 slices. It's a pretty accurate rendition of my Son, The process isn't easy or quick. But the results are really satisfying. If anyone is interested in the steps I would be glad to help them give it a try. Many programs are used and all are free or trial based free.
3D Photo capture - MeshRoom
3D Editing of mesh - MeshLab
3D Sculpting - Mudroom
3D Slicing - Houdini Apprentice
.... and finally VCarvePro.
The process comes down to making traceable bitmaps(with registration marks) of each slice that plays in a sequence very much like the slicing you see of a full MRI. Then carefully ordering your outlines so you know the sequence.
Dimensions are about 20" high. "Resolution" dependent on slice thickness.
I look forward to seeing what you all create!!!!!!
3D Head
- scotttarnor
Re: 3D Head
WOW, Very interesting!
I do not believe I have the patients for this, Good Job !
Scott T
@scottscnc
@scottscnc
- jfederer
- Model of CNC Machine: CanCam D23M
Re: 3D Head
Thanks for sharing this. I've also been contemplating a sculpture, doing it in VCarve to avoid the expense (and learning curve) of a 3D printer. Your sculpture proves I'm not crazy to try this approach. But I don't know if I have your patience!
Joe Federer
www.federer.ca
www.federer.ca
Re: 3D Head
A few years ago I invested several thousand dollars in a David-Vision 3D scanner, that I thought took crappy scans and I had to do a lot of editing and cleanup in ZBrush. I finally sold it for a fraction of what I paid for because I was so dissatisfied. It looks like your approach came out great without a lot of cash layout.
Here are two of one of my granddaughters, the color one 3D printed and the other was done in wood using Aspire using the same scan.
Gary
Gary
- Model of CNC Machine: Homemade
3D Head
.Thanks for posting, and including a description of the process and software
